Kai SRT10
I just got my Gen III back from a local shop.
Here is what I had done:
ported heads Flow: .288 @ .550 and .301 @ .600
Compression ratio 9.9:1
Manley severe duty valves 2.055 intake 1.6 exhaust
Manley dual springs and titanium retainers
Crower custom cam 224/228 @.050 .585/.585 lift with 1.7 Rockers LSA 113
Jesel roller rockers (1.7)
Manley chrome-moly pushrods
Valve cover spacers
VEC 2
I already had Billy Boat stepped (1 5/8 to 1 3/4) headers, high flow cats, and a Corsa track exhaust with cross-over delete.
The results on the dyno were o.k., but not quite as good as I was hoping for. I gained some high end hp and torque, but lost a substantial amount of low and mid-range hp and torque. Here's a dyno graph: The new results are in red (hp) and purple (tq). I am wondering what I might do to claw back some of the low and mid range numbers, and generally improve area under the curve here.
First off, I am going to work on some additional timing and fuel tuning with the VEC2.
If that doesn't accomplish anything, I may have a look at my cam.
My current cam has a duration of 224 on intake, and 228 exhaust. That is compared with 212 intake and 232 exhaust for the stock cam (measured at .050.) The lobe separation angle is 113 degrees (don't know the lsa for the stock cam.)
Lift (with the 1.7 rockers) of the new cam is .585 for both intake and exhaust (compared with .544 for the stock cam.)
The one thing that jumps out at me on the new camshaft is that the exhaust duration is lower than that of the stock camshaft.
Out of curiosity, I checked out Crower's stage 3 camshaft they sell for the Gen III viper. The specs for the Crower stage 3 shaft are 238 duration for both intake and exhaust, and lift of .587 for both intake and exhaust. Their stage 2 camshaft has 230 duration, and .558 lift.
Here's a comparison of my cam, the stock cam, and the three Crower cams available:
--- ---- duration --- lift
Mine: 224/228 -- .585/.585
stock: 212/232 -- .544/.544
st 1: 222/230 -- .563/.558
st 2: 230/230 -- .558/.558
st 3: 238/238 -- .587/.587
Any thoughts?
Valve cover spacers
VEC 2
Any thoughts?
