purplesnake
- Joined
- Jan 15, 2011
- Posts
- 244
- Reaction score
- 0
Or once it is set up, is it permanently locked to that VIN?
Mileage would of course be wrong and if the throttle bodies are not exactly the same calibration wise you could have a problem, but I suppose it might "work" if that was the only option.
So Mark, is there any problem with going back and forth between the original PCM and the race PCM that is now on the car? I just want to experiment because when I put on corsa and high flow cats I put the PCM on so I wouldn't throw codes, but I miss the "decel burble" and I am thinking about switching back. I don't want to screw something up on the car though. Thanks.
No, the PCM once installed and calibrated for the throttle bodies can be physically switched back and forth anytime you want to. You may get a P code for the catalyst inefficiency though without it.
If that happens, do I have to go to a dealer to clear the code? I suppose if it does, I just go back to the race PCM. Again, thanks for the technical help.
Mark, does it make sense to have Dan Cragin or someone else do whatever tweaks they do to the stock PCM to accomplish my goals?
Not possible with the Gen4 cars sorry and Dan is still in a re org state as far as I know if it were a Gen2/3 car.
