Crap.. Coolant leak.
herbbone
Moscow. Pa.
Took car out today and as temp got up I smelled that smell. Didn't see any steam. Turned on heater core no steam. Parked car and notice the tell tale sign of a leak little trail of greenish dots. looked under the hood. I have coolant leak somewhere near the firewall.
Radiator and water pump dry. Head gasket dry. There is coolant on both side of the car under the hood. Ideas? This bites I am supposed to meet up with a few members Saturday for a cruise. :mad:
H
herbbone
Moscow. Pa.
Found bad hose from Heater core to engine. Looks like easy fix. Hopefully dealer has part.
Cape Coral, FL
Hopefully it is just those hose as discussed- if it is anything more, or if you still have all the OEM gaskets in there, you may want to consider changing them out before they DO cause you a problem.
xeng yang
