creeking door
SBMIANO
My passenger door when it is opened fully will creek at the hinge. I have put lithium grease, wd 40 and it quites it a little but still there. Any suggestions???:( :( :dunno:
Alabaster Mamba
Corinth, TX
I know I will get slammed for this but I have used that Prolong Spray on the hinges to quiet them down. It seems to work pretty good but then my hearing isn't the best.
TBarrow
Cypress, Texas
Look at the trim piece in front of the door. Mine had slide back and when the door was opened all the way the two painted pieces would rub and sounded like a squeak. lube will not make it disappear. remove the 3 screws and slide the clips forward a little bit and reinstall the panel. This fixed mine. Good luck as I hate sqeaks and rattles as well. I did sound deaden the entire passenger compartment.
Todd
Midgetfist
Cape Coma, FL
Same creek here. Took off the hinge access panel to discover it was not the hinges, but the composite spring. Only occurs during very warm weather. Perfectly quiet when cool outside.
tbone96
