Curiosity killed the cats.. and resonators.. $150 exhaust project pics
2000_Black_RT10
Up North
Curiosity killed the cats.. and resonators.. $150 exhaust project pics & video
An experiment to determine what the exhaust would sound like with the stock muffler and removing the catalytic converters and resonators. Intentions are buying an entire new exhaust, headers, etc.. but for what it was worth since bored this weekend.. $50 heavy guage (1/8" wall thickness) 2 1/2" diameter tube, $60 for 12 4 bolt flanges, and misc hardware including grade 5 fasteners, and lots of MIG welding. I bought 4 more flanges so I can reinstall the catalytic converter & resonator assembly.
It sounds absolutely awesome, slightly louder at idle, but not much, but when you get on it, it sounds like it should more like a race car. Most noticeable is during downshift, under engine braking it cackles like an Indy car. Overall there isn't a drone, not sure if the heavy guage pipe helped. Surely the sills won't get as hot either, it's a terrible design from the factory, there isn't any room for air to flow around the converter, encapsulating all that heat is not so good.
Original exhaust
Cut front elbow
Cut rear tail pipe
Flange welded on front elbow, I removed the elbow prior to welding, easy to remove at the manifold clamp
Straight tube and old system comparison
Looking inside resonator
Looking inside catalytic converter
Front flange welded and assembled
Rear flange welded and assembled
Finished prior to putting the rocker / sill cover back on
That's it..
AFL in NJ
Rancho Cordova, CA
Looks amazing, any chance you can record some video of it running so we can hear it? If possible, post it on youtube and give us a link to it.
Nice work!
Regards,
Aaron
FE 065
MI
Thanks for the great photos-you're ready to rock now!
:2tu:
2001 ACR/1999 GTS
Chrome ACR Wheels for sale
(24lbs lighter than OE 18")
2000_Black_RT10
Up North
I will tomorrow, road side drive-by footage and in car. :2tu:
Oh ya, I forgot to mention, the cows were lingering around close to the garage.. I snapped this pic just after I ran the car for a few seconds with open exhaust after I cut the pipes.. they didn't like that, they scattered pretty quick..
big-n-italian
Central Illinois
if you want to see someting really amazing, try looking at the sun through the catalytic converter and tell us what you see! ;)
you will quickly realized why your side sills get so darn hot!
RAYSIR
Salem, OR
Man, nice welding job!!! Looks great. Do you have to get seasonal waivers or what about emmision test.
CROM
Fairfax, VA
Nice work! I wish I had your equipment and skills. What MIG do you have?
You're going to need 02 Simulators btw. Unless you don't care about the light.
SSSSE YA
Simi Valley, CA, USA
Great post, thanks for information and pictures. To bad You or some one else could do a dyno pull to get a base line and than after with cats and muffers removed.
2000_Black_RT10
Up North
Here you go Aaron & Chuck, nice day in the country to make some noise.. funny, reminds of being a kid and using a clothes pin and hockey cards on the bicycle spokes.. no sense growing up, life's too short eh' :drive:
5 meg WMV video..
http://www.wincom.net/mnllehti/exhaust_08_06_2007_video.wmv
CROM - thanks for the heads up, I did a plug check, they look good right after a hard run. Theory could be that since the 02 sensors are close to the manifold, not using headers didn't really affect the heat output, plugs look ok, it runs good..
It's just a portable Century 120v wire feed / MIG welder, thanks for the welding compliment RAYSIR.
The sills are only warm now, heat is gone, I checked after idling and hard runs. That's it, thank you for the chance to share the fabbing and the compliments everybody.
2000_Black_RT10
Up North
If you want to make your own, here are some more pics and materials.
The straight pipe is the typical galvanized electrical conduit tubing from Home Depot, it's 2 1/2" diameter, and 1/8" wall thickness. You can buy a 8' length. Cutting the original exhaust pipe at the straight section (not at a bend) ended up being a 41" straight pipe, plus the flange thicknesses. I guess you could use thinner pipe, but I wanted something nice and thick, easy to weld (without burning holes through it) and surely quieter regarding noise in the sills. Bolts were 3/8" - 24 (fine thread), grade 5, 1 1/2" long, also used lock washers in addition to flat washers.
I used a cordless Dewalt reciprocating saw to cut the pipes, just put a jack under the assembly so it doesn't fall and kick up, possibly hitting the car, just make the cut straight as possible, once it was cut it didn't fall, I just rolled it out..
I cut a piece of exhaust tubing to center the pipe in the flange so I could tack weld the pipe centered in location, because the 2 1/2" pipe did not slip into the 2 1/4" hole in the 4 bolt flange, needing somethig to center it rather than try to hold it in position.
Here it is slipped in, this will be removed after tack welding.
Bolt the straight pipe flanges to the flanges that were welded to the original exhaust, the straight pipe needs to be cut at an angle, approximately 5 degrees on the chop saw, the pipe is not cut at a straight / perpendicular angle, if you look at the previous picture of the original catalytic / resonator assembly, the inlet and outlet is not on the same center line, this pipe is at an angle, also considering the handheld cut using the reciprocating saw is not perfect either..
I used one fo those long pipe clamps to hole the entire assembly together at the flanges, you can see it on the floor after I tacked welded the flanges. Since the front elbow is a flex pipe, you have about +/- 1/2" to play with front to back, just cut your pipe longer and keep cutting it back until it fits nice at both flanges.
After cutting the pipe, it may be trial an error to get a flush fit to the flange since it's cut at an angle. Then tack weld it to the flange.
Once it's tack welded at both ends, remove the pipe and finish welding the flanges to the straight pipe.
I made my own flange gaskets using thin alloy, copper would be best, you can get flat stock copper from any place that sells roofing decor / flashing, etc.. if you can't find matching prefab flange gaskets.
That's it..
CROM
Fairfax, VA
Sorry for the confusion.
What I meant to get across was that without the catalytic converters in place there is a good chance you will throw an engine light.
Thanks for the extended writeup/pics :2tu:
2000_Black_RT10
Up North
Thanks CROM, it is good to hear feedback - I'll be aware for the dreaded engine light. I drove about 2 hours today, from ripping around like a maniac to getting stuck idling in a long line of cottage traffic that were returning home on the long weekend. I will be sure to give notice if it happens.
2000_Black_RT10
Up North
You are right Aaron, I couldn't put my finger on it, definitely Can-Am. Thanks, I wasn't sure what to expect when I pulled the trigger on the saw, it all worked out ok. :2tu:
CROM
Fairfax, VA
When the light does come on use a little of this and you'll be all set. :D
big-n-italian
Central Illinois
everyone said it would, but it never happened on my 97.
CROM
Fairfax, VA
96s, 97s and early 98s tend to slip by somehow. OBD2 went into place in 96, and typically most 96+ makes/models throw that pesky code.
That a 2000 "should" throw the code
ZEUS
Toronto, Ontario
Ever since I gave you a blow by a while back, you know you've been yearning it ever since. :D
PS- Get some hi-flows, they'll take away most of the annoying "pops" and keep the good ones. Noise will sound only slightly less, specifically high treble. More importantly, this non-cat viper won't smell as good as your 572 cuda did, it actually stinks---your wife will hate it with the top off at a light. Tried both set-ups, and if only for the sound hi flows are worth it.
2000_Black_RT10
Up North
2 days of driving (approx 4 hours total), still no light / code! :D
I really enjoy driving the car even more now, it's been great so far.
Ar Tee Ten
