Differences Between 93-95 Vipers?
Literally over 200+ differences from 1993.01 and the end of 1995. Casual observers wont spot ANY. Can you narrow your search?
IF you can get a spring issue of Viper Mag $6 at 1-800-998-1110, some yo-yo wrote up a lot of em....... got most of em RIGHT too!
Matt
San Jose, CA
Probably the only major thing to consider would be that there seemed to be a bit of an inprovement with the head gasket issues on the 95's. There seem to be less problems with 95's having leaking head gaskets.
95 was also the last year of side pipe exhaust. Oh, also, I believe some early 93s had a rear-fender mounted antenna.
Overall, not much noticeably different, but as JonB mentioned, many running refinements and tweaks.
-Matt
AndyR
Cincinnati
Most obvious is early 93 driver's side rear fender mounted antenna and battery in CENTER of trunk under spare. Also, exhaust is mounted with spring mounted clamps, I'm not sure when this changed though.
Jay Herbert
Sunnyvale, CA
Marv, Thanks for posting the link to the product chronology page. We are still tweaking it (note color table is missing a bit of info and "color swatches") and have a lot of thinks to add to the 92/93 part of the chronology. We pulled this info from lots of different places on the site and consolidated it in one place as many wanted to know the exact changes by year. We plan to make it a "visual guide" as well.
Our '92 Registrar, Pat Wnek, is pulling together a lot of details on the '92's (he has one
)and we are working with DC on VIN/build info, info that once all in place, will blow peoples minds.
xeng yang
