Does this sound right about service??
wes
League City
Well it's too late now cause I'm already having it done but my car threw a code p0123 which is high voltage in the TP sensor a few days ago. Soooo I read on here and changed the TP sensor and cleaned the IAC and it didn't work. The car got so bad yesterday I had to get it towed to a close dealership because I couldn't make it to Tomball dodge. It was bucking and bogging down bad and was shooting black smoke out of the exhaust. Anyways I just picked up the car about 2 weeks ago and I know it was sitting at the dealership where I bought it from out of state since april this year. The dealer said it could be the fuel and they want to do the following. Drop the fuel tank and clean it out, replace spark plugs, clean the injectors, and clean the throttle body. They want $815.00 which includes the cost of the tow there (which was 85 bucks) and new fuel. So my question is does this sound like it could be the problem. I fear that even after all this is done the the code P0123 will still not go away. I'm just wondering if the car sitting since april would cause all these problems or not. Thanks a lot.
Wes
THE YEAR MATTERS
THE MILES MATTER
THE MODS MATTER
That said, their shot-gun approach does NOT sound likely, just guesswork.
Gen 2? Depending on answers above, could be oxy sensors, or even cats, fouled by some other thing like injector, coil, plugs, or that BAD TPS you replaced...
NOTICE TO EVERYONE: When you ask / answer a question: THE YEAR MATTERS !!!!
To answer your last question: Did the battery die during April-October storage? If so, it might just need a new battrey, and a re-learn of the idle program. YEAR MATTERS. Fuel does not go bad in 6-7 mos.....esp for a low-compression, low rpm motor's needs
W
wes
League City
2006 coupe
7900 miles
the only mods now are corsa exhaust
it was supercharged by the previous owner awhile back...don't know when to be sure..I don't know if the battery died or not during that time period.
slysnake
2006 coupe
Are the gas tanks in the coupes different than the tanks in a vert? Because in a vert there is no "dropping the tank". To remove the tank requires CUTTING A HOLE in the rear trunk!
W
wes
League City
stuff just isn't adding up..I'm thinking I'm just gonna have to **** it up and lose a couple hundred for the tow and "diagnostic charge" and take it to a dealership that actually knows something.
plumcrazy
ALL OVER
there are VERY few dealerships who know anything about vipers....
ART in buda texas.
W
wes
League City
While I hear ART is good they are a little far from me..bout 3 hours. I've heard some good things about Tomball dodge and hear the tech there is very good. I'll be talking with him tomorrow.
JKGiant
