Door Panel Removal
srcsrt10
How difficult is it to remove the pass. side door panel on a 03 srt10, and is it possible to get the window down if the power windows bad. Any help will be greatly appreciated.
redtanrt10
Dana Point CA
The panel removal is pretty straigtforward, 5 or 6 screws plus 4-5 push pins. Perhaps after removal you might find loose wires/harness causing the window not to work? If you need help send me a PM and I can walk you through or fax the proccedure from the shop manual.
Mike
