Driving your car without the side sills
bth1
New Jersey (Union County)
I seem to remember a post (I can't find it) that indicated you should not drive your Viper without the side sills and insulation because the heat will damage the body parts that normally sit above the sills.
I am going to be putting on some new cats and was wondering if I could drive the car the 10mn or so to the exhaust shop or whether that would be too much. If it makes a difference it has been really cold here in NJ.
Thanks,
V10SpeedLuvr
My car has been side sill-less for 3 weeks now waiting on them to get painted :curse: I've only driven it once in that time (maybe 40 miles total), but I didnt notice any heat problems. I remember a guy saying he drove around in his Viper without his sidesills while he had exhaust work done and he didnt mention any negative side effects. For 10 mins, I think you'd be fine.
plumcrazy
ALL OVER
i'll be doing the exact thing in a few weeks when i go to the muffler shop for work..dont sweat it, its gotta be better for heat as there isnt anything above them then.
2000GTS
Miami, FL
Drove mine for 4 days while one of the sills was being painted. No problems.
I would think that the exhaust would remain even cooler with the sill missing because of all the airflow.
Big E
Missouri
Very true. Cool weather + airflow should be no problem. Just don't set there and let it idle for long periods. I'm cat-less so there is even less to worry about.
FLX109
Massachusetts
I drove mine aprox 80 miles in the hot summer with no side sills to a muffler shop to get the exhaust welded together when I coverted to side exhaust and had no problems at all, I though it actually ran cooler.
FLX109
Ron
Indianapolis
As a contrarian, I'd only suggest that the plastic door is right above the cat and heat soak after the run is when max temp on the door would be reached. Perhaps no issue, but something to be aware of.
RAYSIR
Salem, OR
Seems there would be more air circulation on exhaust without them. Not contained. I'd do it.
Missjazzyfitness
