Dyno 97 GTS w cat-back, tubes, filters, VEC
Jay Lopez
Dallas, TX USA
Here are the dyno results of my 1997 GTS, 30,000 miles, Roe Racing VEC (+8, -8 settings), Borla Catback, Smooth Tubes, K&N filters.
Date: 1-20-01
Max Power at rear wheels: 421.0
Max Torque at rear wheels: 463.3
Jay, did you monitor the air/fuel ratio with the VEC installed? I ask because we ran dead lean on a '97 GTS. So lean that we removed the VEC to prevent damage to the engine. The supplied AFR gauge said it was running just about a perfect AFR, but the wide-band AFR on our dyno said otherwise.
Sean said he hadn't seen that before, but I talked to a couple people who had experienced the same thing. I think there are a lot more VECs out there working properly than not, but it's worth it to check the AFR using a wide-band unit to make sure everything's hunky dory in there!
potterb4
