I have to agree - My pulls have been by the the builders of Dynojet. I have had a consistency between successful pulls, but, I have also had a consistency on a different dyno. They manufacture the dyno's and I have been on four separate machines and all have been within a few hp/ft-lbs. All these have been with the same operator. He is also the instructor for those that buy a dyno.
If the operator is knowledgeable the pulls will show consistency. If not? - with the Viper it is easy to alter the max torque if the operator is not consistent. The torque can be manipulated by starting the pull at diferent rpm's. True performance is measured by the an overall raise in the curve between 3500 and 5500, therefore, small anomolies are meaningless.
Because of the Vipers torque it is especially ******* the half shafts to start the pull at anything less than 3000 rpm's. This is exacerbated by any mod's such as nitrous or supercharging. Try starting a pull at 3000, versus, 3500 and you will see substantial difference in peak torque, however, the overall curves will fairly close. With the Viper a meaningful pull is 3000-5000, anything else a waste.
Another issue is the degree of smoothing utilized on the graph, and/or which correction factor is used. If little or no smoothing is selected the anomolies (spikes in hp or torque) will be measured and the measure quantity will be higher. It is unlikely that different selections would be used on succesive pulls, however, it could happen. The operator error can be with the actual pull, or with the familiarity of the software. Remember that coolant temp can also affect hp to some degree.
I don't understand why most of the curves posted don't show the a/f ratio below the power curves. This is as important as the hp/torque and we could all learn alot if the a/f curves were also posted. If your operator is not printing these, tell him to do so.
Can anyone beat 750 rw ft-lbs for a Gen I.
