valentine_viper
I dyno'd my '04 Viper today. Conditions were 75 degrees, 29% humidity, 30.01 barametric pressure at 65 feet above sea level. Car is 100% stock right down to the air filters. This was on a Dynojet.
Peak rwhp was 442 and torque was 482.
The numbers were good, but we did find a surprising anomally in the A/F ratio. Between 3000 and 3600 rpm, the A/F when very lean (although not quite lean enough to be dangerous) and then went fat for the rest of the run. The lean spot caused the torque to dip by 80 lb ft and the hp to take a similar dip. After that, the curves were smooth as would be expected. I understand that these are tuned from the factory to run rich in order to keep the cats running cool (good for longevity, bad for power), but don't think the dip is normal. We made 4 pulls and the dip was consistent through all of them. Surprisingly, I don't really feel this when I'm driving. The car does seem a little soft on the bottom end, but you can't feel a dip or stumble. I did get a couple of backfires the other night while doing some spirited driving. Perhaps becuase of the lean spot?
Has anyone else encountered this?
May send the computer to DC Performance for a reflash.
