Easiest way to remove 1994 RT/10 Glove Box Door?
Roadkill
Norcal
I pulled mine off the other day.. easiest way is just to pull the entire dash loose.. should take 20 minutes or less.. the door is held on with two push pins i imagine if you could get a slim screwdriver in there, you could wedge it apart.. but damn if i wouldn't be afraid of the parts dropping out of sight.
Rollin4
Anacoco, La.
Roadkill is right pull the dash. There is a button inside your headlight switch on the top, push down on it to remove the handle and knob for the lights, be careful and don't pull to ******* the handle.
gotV10
Atlanta, Ga
actually the easiest way is with a claw-hammer, but reinstalling it afterwards is a little tricky. sorry you asked the easiest way
as stated above remove the dash and be very gentle using the screw driver
ryan
VinhyVegas
