Sean Roe recommends this mix:
-> Prestone 50/50 ELC
-> (2) Redline WW
Chuck is a lifetime NRA member, so we know he has firearms, but I'd prefer to see them arm wrestle.
BTW, first I've heard anyone say no to WW, and I have the Roe mix in my GTS.
Did all this at once when I replaced what could have been the OE coolant in my '01:
-> RDR aluminum radiator
-> New OE water pump
-> 180 stat
-> Roe hoses
-> New OE sending unit
-> Flush with water and refill with above
Already had the Roe duct in.
I did this last Nov, and have the prior summer's experience with the old parts.
Car definitely responds quicker to cooling after a load, like driving hard.
Also runs cooler while moving under load.
However, sitting in traffic on a 30 deg (F) day, the temp will go to the fan run point of 220 or whatever it is. And cool almost instantly when I start moving again.
Point is, sitting still there is no air moving over your liquid to air exchanger known as a radiator. Until the fan comes on.
