Finally Got My Car Back (and it is evil)
Kai SRT10
Salt Lake City
Some of you may know that I have been without my Viper for almost a year and a half. I blew the engine at a track day (oil starvation, spun the rod bearing, blew rods and pistons, and damaged the sleeves, then the oil leaked down into my exhaust, caught fire, and destroyed my cats.) Rather than rebuild it back to stock configuration, I embarked on a program to build the perfect Viper.
In spite of good advice from a number of well meaning folks, I initially took my car to a local shop without much Viper experience. Fourteen months later, I did what I should have done in the first place and shipped my car to Dan Cragin at D.C. Performance in Los Angeles. Kevin Singleton at Exotic Engine Development built the engine, and Dan Cragin and his crew did the engine install, tuning, clutch, exhaust, and a bunch of other stuff. Last Friday, I picked the car up at DC Performance, and drove it home to Colorado, (including some detours in the mountains above Malibu and twisty Utah canyon roads,) I have to say that (for me) this is now the perfect Viper. There are cars that are more powerful, or more smooth or faster, or better looking, but for me, my car is now the the perfect combination of sound and fury.
I have never driven a wilder car. Thanks to the ultra light clutch and flywheel and a crankshaft that is 30 pounds lighter than stock, the driveline has radically reduced rotating mass, and the effect is readily apparent. It revs immediately, with no hesitation at all. I have a Subaru WRX STi, with a horizontally opposed 4 cylinder engine. I used to think that the STi engine was free revving. My new Viper engine takes it to another level. Revving the Viper engine now sounds like revving a giant V-10 chain saw. It has more “bark” to the engine note, and it drops off just as quickly when you let off the gas. As a practical effect, when driving, throttle response and acceleration is immediate. Initially, it was a bit too immediate, and I ended up lighting up the tires more than once by accident. Driving the car requires a fair amount of attention, as when you shift, the rpm’s drop very quickly, which means you have to really “blip” the throttle on downshifts, and be very very quick on upshifts.
Power is significantly higher than stock. The car put down more than 700hp and 700 lb-ft on the engine dyno during break in. Combined with the very quick throttle response, the effect is pretty frightening. I (inadvertently) managed to break the rear tires loose at over 70mph while passing a group of cars on the way home simply by pressing down on the throttle too hard. I’m going to have to learn to control my right foot if I plan to keep myself and my car in one piece.
The clutch is really surprising. The car has a Tilton 3 disk carbon/carbon clutch and lightweight flywheel. I bought the clutch system from Daniel Lesser at Viper Specialty Performance (He goes by “Final GTS” on this site.) I knew that the clutch would be strong and have serious clamping power, but I expected it to be barely drivable. However, after an initial break-in (courtesy of 3 hours of stop and go traffic getting out of Los Angeles,) where the clutch squeaked and grabbed like crazy, it settled down a lot and is now very streetable and tame. The clutch has a very short stroke, and takes a fair amount of effort to depress, but it modulates easily. Given its torque handling capacity, I still can’t believe how user friendly it is.
The car drives a lot like a race car. It’s obnoxiously loud over 2800 rpm, and it bucks and jerks at low speeds when the rpm’s are between 1100 and 2200. However, I’ve found that if I shift immediately from 1st gear to 3rd or 4th, I can inch along in slow traffic below 1000 rpm without any drama. For all its complaints and finicky behavior when driven slowly, the car simply goes nuts when driven hard. Rear wheel traction seems to be the only limiting factor on acceleration. I replaced the stock transmission with a race version that is not only stronger, but has closer ratio 5th and 6th gears. This makes 5th gear less of a stretch when upshifting from 4th, and makes 6th gear useful for something other than highway cruising. Sixth gear now equates to 2500 rpm at 100mph, which extrapolates to 5000 rpm at 200mph, which I have no doubt the car will do easily given a straight, smooth road.
Another surprising thing was gas mileage. I averaged about 17mpg on my trip home, with several tanks averaging almost 20mpg when I was behaving myself and just cruising along.
I don't have space to list all my modifications, but here are some of the highlights:
Engine:
Pretty much everything on the engine is new. The damaged block was bored out to 4.125, and Darton wet sleeves installed. I retained the stock stroke, for 529 cubic inches.
I had a lightweight solid billet crankshaft made for the car that weighs 30 pounds less than the stock crank. Lightweight billet rods, billet main caps, and pistons, coated bearings, heavy duty fasteners etc. round out the bottom end.
Heads are the top of the line Stryker race heads, with top-end valve train stuff etc. with Jesel rockers, and a custom ground cam from Kevin at Exotic Engine.
The car now has a 3 quart accusump system I purchased from Daniel Lesser from Viper Specialty Performance. Also from Viper Specialty Performance is the ultra light weight 3 disc carbon/carbon clutch and flywheel from Tilton.
If you are interested in my full list of modifications, you can see them here:
http://www.cardomain.com/ride/681231/6
Overall, I couldn't be happier. After 18 months and more money than I had to spend, I now have the perfect Viper.
Kai SRT10
Kai SRT10
Salt Lake City
congrats on getting your car back. are you going to put the car on a chassis dyno? It really sounds like one very fast machine.
Yes. I'm going to dyno it.
There is a local dyno shop where I have dyno'd my car since it was stock. I'm going to take it there because they have the data from my stock runs. It will give me a good comparison.
Sound clip is on the way.
Y2K5SRT
Overland Park, KS
Some of you may know that I have been without my Viper for almost a year and a half. I blew the engine at a track day (oil starvation, spun the rod bearing, blew rods and pistons, and damaged the sleeves, then the oil leaked down into my exhaust, caught fire, and destroyed my cats.).
Man, I'll bet the heads didn't fair too well either! :( Congrats on the new-and-improved Viper! I am hoping mine comes back soon too... :2tu:
valentine_viper
Cherry Hill, NJ
Sounds awesome! I'm really curious to hear how it behaves on a road course now.
Please post a report after you have a chance to track it.
ILLSMOQ
SAN JOSE, CA
Good to hear Kai.
On their site Exotic Engine Development made mention of being affiliated with CDI? That sounds good/expencive :)
How long did they take to put the motor together? What kind of warranty do you get on a "Race" engine like that?
Kai SRT10
Kai SRT10
Salt Lake City
I'm not sure what the affiliation is with CDI. I think CDI closed down a few years back. Maybe Kevin used to work there, I have no idea. I do know that EED still is involved with building engines for a number of racing teams. EED isn't the least expensive builder, but I doubt they're the most expensive, either. I do know if I had gone to EED in the first place, it would have cost me less money than I ended up spending.
No idea what the warranty might be. I'm expecting that it won't become an issue. The engine has a conservative tune, as we didn't feel the need to wring every last ounce of power out of it with agressive timing/fuel trim (and it's tuned for sea level and I live and drive at 5600 feet.) Everything in the engine is about as strong as it can be, so the internals are all capable of handling a lot more power than this engine is making. Hopefully, this means it will be pretty durable.
Certainly 1300 miles of highway driving and canyon carving didn't phase it. I'm taking it to the track this Saturday, so it's first real test is coming up shortly.
It took about 5 months for everything to get finished. That included the engine build, and a bunch of other stuff. The engine build took a bit longer than it should have because Crower sent parts that were out of spec.
Good to hear Kai.
Viper X
Kai,
I saw your car at DC a couple of weeks ago. Glad you're "back in the saddle".
Dan
repiv
Kai,
Congrats, it has been a long road. Enjoy that car!
Kai SRT10
Kai SRT10
Salt Lake City
Awesome..who did the crank ?
Crower did the custom crank and custom rods. However, I can't really recommend them. It took them 7 months, cost $6500, and the crankshaft was out of spec (didn't even fit with the rods that were supposed to be part of a "matched system.") The crankshaft had to be reground (mains and rod journals) and the nose that goes in the oil pump was also too long and had to be fixed, as it was ripping the pump up. Everything then had to be re-coated because of all the grinding.
I would go with someone else if I were doing it over again.
Camfab
SoCal
Wow, I was wondering what ever happened with you engine build up. It's nice that after all the pain and cash out lay you finally got something great. Got to love those Big Bore motors!
Kai SRT10
Kai SRT10
Salt Lake City
I got the car chassis dyno'd today. 609rwhp 609rwtq
One thing I forgot to mention earlier is that the car (with a full tank of gas) weighs 3368. I don't know how much the stock srt-10 weighs, but I'm pretty sure I've lost some weight on the car, even with adding the roll bar, fire supression, accusump, etc.
Dave T(BADVENM)
Hey Kai, look forward to seeing you at some NASA rocky mountain events. Just got my truck finished up and tuned from Joe at PBJ.
Will you be at the May 6 Mopar at Thunder Mountain event? The CO chapter of the Viper club will be there. I'll be there with my Paxton SRT Ram.
I was hoping to meet you at the LaJunta event last weekend but mother nature had other ideas.
VENOMAHOLIC
Rochester, NY
I am a big fan of NA horsepower. Sounds like it was well worth the wait. I bet the custom crank took some time as well. Glad you are back on road again!
shibbydude
