For Sale: 1997 Dodge Viper GTS Heads Cam Engine CCW Wheels Racing Seats Roll Bar Cust
KDR83
Tampa, FL
MORE PICTURES:
http://s1027.photobucket.com/user/Yannimelissas/library/?view=recent&page=1
Miles: 26,500
Price: $37,500
Shortly after acquiring this car, I was laid off and was forced to take a significant hit in my income so I have decided to sell this beautiful Red Viper with White Stripes (vinyl, so they can be removed). The previous owner of the car was Jack from this forum and he owned the car since 2002. I have not even had a chance to register the car as I was laid off shortly after taking possession. I have a stack of receipts and papers that go with the car.
The car runs excellent and early in 2013 it ran a 10.9 at 128 mph with a DA of 2500. This car is capable of a 10.5-10.6 sec ET on a cool day and at sea level. It has also done back-to-back 129 runs on a day with a 3000 DA. The Jeff Moray heads/cam is actually as streetable as a stock car.
1997 GTS - 26,000 Miles Red/White Stripes
Royal Purple HPS used since 10,000 miles
ENGINE
Jeff Morey Stage III Heads and Cam - 10.5:1 Compression/Bee Hive Springs/Larger Valves
Head Studs -ARP Kit
Bellanger Headers and Exhaust - Catless
Accufab Throttle Bodies (new 2012) - Intake ported to throttle bodies
Stage 8 Locking Header Bolts
T&D Rockers -Matched/machined to Head Stands
Trick Flow Chrome Moly Push Rods -
Fuel Rail -
50 LB Injectors
Injectors Balanced by Tony Armour
Boost-A-Pump
180 Degree Thermostat
Accusump (3 qt) - Ignition operated with shut-off switch
2000 Model Year 10 Qt Oil Pan - Hinged Trap door and Custom Windage Scrappers
ACR Oil Filter Adapter
Custom Cold Air Box
Roe Red Silicone hoses with Bleeder
Catch Can with PVC rerouted to can
Roe Breather on Valve Cover
Roe Cold Air Inlet at Chin
Underdrive Pulley
Burping Tee at Heater Box
Custom Spark Plug Wire Looms
Red Silicon Coolant Hoses
Drive Train
John Dinoto built transmission
SVS Billet Shifter
Billet Cross Member
Spec Petal Type Clutch
Uitrax Half Shafts
Roe Clutch Pedal Travel Reducer
Drive Shaft Loop
Aluminum Belly Pan
Archer Anti-Toe Brackets- Only fits on one side due to 998 recall
Half Shaft loops
Line Lock
Tuning
SCT Pro Racer X2 Tuner - Multiple tunes go with car/X2 tuner allows full tuning
Innovate A/F gauge and logger (DL32) -A/F Gauge is in OEM Voltmeter Position The logger is set up for A/F, Throttle, RPM, Fuel Pressure and Vacuum
Two Position Pillar Gauge Pod - Voltmeter and Fuel Pressure
Raptor Shift Light
CHASIS
Race Alignment at 25,000 miles
CCW Classic Wheels w/PS2
BTR Roll Bar - Red powder coat
Woodhouse Adjustable Sway Bar
Fire Suppression for Engine Bay
Toe Eyes Front/Rear
Power Steering Captive Cover/Breather
Tom's Rear Brake Kit and Proportioning Valve
Slotted front rotors/aluminum hats
New Rear Rotors
Track brake pads
Differential Pinion Arms Poly Bushings
INTERIOR
Carbon Fiber Center Console
Carbon Fiber Radio/AC Surround
Dash Painted Black Satin (professionally) - Original dash was stripped, sanded, primed and painted
2008 SRT Race Seats by Verzano
5 Point Seat Belts - Drivers and Passenger
Custom Sneaky Pete Floor Mats
MGW Short Shifter/Grip
MGW Radio/AC Knobs
MGW Gas Cap/Door
MGW Console Compartment w/Cup Holder
MGW Ash Tray
MGW Lighter
MGW License Plate Holder
Chrome Gauge Surrounds
Black/Red Shift Boot and E-Brake Boot - By Redline
Air Flight Aluminum Pedals
Air Flight Sill Kick Plates
Sony Radio & Explod Speaker System
Miscellaneous
Painted Viper Logo Hood Pad
Extra remote/key fob
Chrome OEM GTS Emblems Side/Rear
Full 998 Recall Done
OEM Chrome Factory GTS Lettering Side/Back
Optima Red Top
New Drivers Door Spring - 2012
Rear Glass - New Gas Shocks 2010
viper k
Re: For Sale: 1997 Dodge Viper GTS Heads Cam Engine CCW Wheels Racing Seats Roll Bar
very nice viper and thats a good price good luck with the sale!!!!!
K
KDR83
Tampa, FL
Thanks! Hopefully it goes to a good home
IDM
London
bump for you!
Tombala
