Forced Induction 1/4 mile times
black mamba1
CT
Post em if you got em! If your Viper is supercharged or twin turbo or even the NX and you have timed yourself in the 1/4 mile, post your time, mods, tires, and track conditions here. Time slips preferred but not required. :D
Lets see whatcha got!
RobZilla
Jacksonville, FL USA
I have not had a chance to go since the addition of my S/C.
Prior to it was 12.03 at 119. Only my third run ever in any vehicle.
:usa:
Madduc
Fremont,MI
I posted my last time slip in the Time slip forum, First time with my 97GTS....10.75 at 130
Viperless
MN
Ran three 10's in a row. 10.86, 10.85 & 10.87 all at 134mph. Roe blower, 10psi, BFG drag radials. Horrible track conditions. This was at Rock Falls Dragway and they call it "the slippery rock". Kind of hard to hook up 650ft lbs of torque at 2000 rpms though. Temps were probably in the mid to upper 60's.
Don't have a scanned image of the timeslip but how about a video.
Viper GTS 10.86 Run at Rock Falls - Car Videos on StreetFire
black mamba1
black mamba1
CT
those are some kick ass times. What kind of rwhp was the Roe making?
Viperless
MN
Not bad, not bad. Have you ran your 09 in the 1/4 yet?
After some more tuning, a new fuel system and switching to E85, it made 710. Never got a chance to run it on the strip after that though.
Planning on running the '09 this fall.
Bandit400
Central, NJ
Totally doging it off the line on my BFG drag radials. Englishtown Raceway Park.
10.63 ET @ 141 MPH.
This is with 10lbs of boost.
Bandit400
black mamba1
black mamba1
CT
10.63 ET @ 141 MPH.
Bandit400
Great time! One of the best I have seen. Is your transmission stock?
Simms
Pittsburgh, PA
Thanks to 1TONY1 for compiling this. It may be a little out of date now, but it has a lot of good times.
V10, six speed, independent rear
7.98@183 Garth (HIBOOST) 12/?/2006 1.296 sixty, built by Under Ground racing, Driver: Kevin Howeth of UGR,
[email protected] David Boggs (Dr. Roof) 11/18/05, twin turbo, built by Under Ground racing, Driver: Kevin Howeth of UGR,
8.75@168 Chad Williams ("Chad"), 12/12/04, twin turbo, built by Heffner Performance, First 6 speed Viper in the eights. Driver: Chad Williams
8.75@163 Jerry Kennedy (Ripper02) 3/8/2006, 1.363 sixty, twin turbo, built by Heffner Performance, Driver: Gary Javo
9.27@149 Brian Anderson (2MANYTOYS), 12/12/04, Underground racing, Supercharged/Paxton, driver: Kevin Howeth
9.28@151 Tony Armour (1TONY1), 12/9/06, 1.417 sixty, Roe supercharger & nitrous, built by Armour Racing, Ringgold, Ga.
9.45@157 TwinVipers, 4/19/05, built by Heffner Performance, twin turbo, 510" stroker,
[email protected] Rohn Kittle (jkracer), 11/20/02 nitrous, Racing Solutions, driver: SW "StreetKing"
9.48@146 Norm Korner (TX Whos Your Daddy) 12/9/2007, ALL MOTOR WORLD RECORD, built by Lingenfelter Performance, Driver: "BIG GUN" SCOTT WIECK
[email protected] Ronnie Skaria (RSI950) 12/12/06, 1.39 sixty, built by Racing Solutions, Paxton s/c
9.52@151 Jason Styles, 2003, Paxton/Nitrous, RSI, driver: Albert C.
[email protected] HMS, 3/12/05, Hennessy Performance 2003 SRT10, 522 cubic inch twinturbo, stock heads, 9.57 @ 151.8 mph
[email protected] Tom Welch (ViperJEDI)(date) BTR heads and nitrous, built by BTR Performance
9.63@151 David Boggs (Dr. Roof) 12/2003, Paxton supercharger, Doug Levin Motorsports,
[email protected] Albert Chloubler, heads/cam, direct port nitrous
[email protected] Ward Reasoner (Cudaman)12/4/04, Roe supercharger & nitrous, Macedo Motorsports,
9.75@143 Matt Yates (BlownGTS) 12/2003, 1.43 sixty, Paxton S/C, stock motor, built by Under GroundRacing
9.82@152 (yellowstain) 12/9/2006, sixty?, twin turbo and nitrous, Gen1, built by Macedo Motorsports
[email protected] The "SW", 12/12/04 510 ci stroker, ALL MOTOR !!!
[email protected] Rich (Mojo) 12/12/04 heads/cam, nitrous,
10.08@144 John Canal, 2005, Roe Supercharger and nitrous, stock creampuff w rockers, built by Macedo Motorsports
10.12@143 Joseph Dell (JD), 12/12/04 on drag radials, Doug Levin Motorsports, supercharged.
10.19@135 John Smith (JDAWG)12/12/04 heads/cam/nitrous Bradenton Fl. creampuff pistons, Heffner heads, HMS cam, installed by Armour Racing
10.29@136 Mike Robbins (Blebyu) 12/9/06, 1.49 sixty, Roe Supercharger, stock motor w headers, no nitrous, no water/****, tuned by UtahViper
10.40@134 (Steve@AZPS) 1.46 sixty, heads, bolt ons, nitrous
[email protected] Mike Scherzsburg (99 RT/10) 12/12/04, 1.55 sixty, Roe Supercharger and nitrous, built by Macedo Motorsports
[email protected] (JohnnyBravo) 11/4/06, 1.52 sixty, Roe Supercharger w headers/rockers/drag radials, built by Joe Dononvan
10.55@133 (Simms) 12/9/2007, 1.487 sixty, Roe Supercharger, built by Macedo Motorsports
V10, six speed, independent rear, TRUE RADIALS ONLY: Michelins/Pirellis etc. No Kuhmo's or drag radials
10.40@136 Rick (Rick-SRT10) 12/9/2006, 1.65 sixty, built by Doug Levin Motorsports, gen3, Paxton s/c, 19" Pirelli P Zero,
[email protected] Tony Armour (1TONY1) 12/9/2006, 1.86 sixty, Roe Supercharger and nitrous, built by Armour Racing, 17" Michelin,
[email protected] Tom Welch (ViperJEDI) 12/2004, BTR heads and nitrous, built by BTR Performance, Michelin,
10.50@143 (kllymartin) 12/9/06, 1.76 sixty, twinturbo, 522ci, 20" true radials, built by RSI
V10, auto or non-stock tranny, INDEPENDENT REAR.
[email protected] Chad Williams, 3/12/05, twin turbo, Heffner Performance, turbo 400, First in the "sevens" driver: Tony Armour
[email protected] Sal (Viper TT) 1/2007, 1.348 sixty, twin 88mm turbos, 575ci, power glide, Built/driven by Steve Drummond Race Cars,Turbo System by Heffner Performance / Turbo People, DRAG RADIALS
[email protected] SVSi twin turbo 8/27/05 SVSi Racing, powerglide, best ET 8.44
[email protected] Terry Ruots, 5/16/03, Hennessy Performance, twin turbo, nitrous, stock pcm, powerglide
9.15@153 Bob Helms, 4/04 RSI 1200, Paxton S/C and Nitrous, Powerglide
4.91@151 1/8 mile, David Boggs, (Dr Roof) 2/2007, twin turbo, built by Under Ground racing, Driver: Kevin Howeth of UGR, turbo 400
V10, auto or non-stock tranny, solid rear axle.
[email protected] Lee Saunders, 1/25/2007, 1.244 sixty, twin turbo, 9" solid axle rear, turbo 400, built by Heffner Performance
9.XX@1XX Tommy Fudge (date ) All Motor, 9" solid axle rear, automatic
Tusc
The (UN)Constitution State
Excellent post.
Does anyone have numbers for a 5# Roe kit on a stocker or the same but with headers/cat-back?
Curious what a simple setup is capable of with a little boost. Any rwhp numbers?
Ray W
Fort Lauderdale,FL USA
Man I miss those days. :(
Black Mamba, 1TONY1 is your best example for how tires effect e.t. With slicks instead of drag radials only a 2mph increase,but over a full second better in e.t.
10 flat in a Viper in street trim or with drag radials would be the holy grail. A car that wouldn't even hook-up below 100 mph.
black mamba1
black mamba1
CT
This is the most informative post I have ever seen on forced induction 1/4 mile times. This gives a good idea on just how fast these cars can be!
I'm getting a Paxton. Case closed.
DJ'sviper
all stock 7.89 94 mph 1/8 mile stock tires. '93 Just for fun. at the closer track do 8.1 to 8.2
Junkie
10.55 at 130mph this weekend, nosing over pretty bad in 3rd/4th. Its got alot more in it
stock motor, paxton, 6spd
Ray W
On a Gen 3,Paxton is the best and most affordable way to go. My advice is to get as much hp that you can using pump gas. Keep in mind that using race gas and water injection systems can get old after a while. Especially when the extra power might be unable to be used.
ViperGeorge
Greenwood Village, CO
Those are some great times, certainly better than anything I could do. What's the secret, if any, for launching a Paxton, Gen 3 with street rubber (Michelin PS2s, not run craps)? What RPMs should you start at? Do you dump the clutch and then feather on the gas? Do you feather the clutch? How do they get such good 60' times? Anything different when launching a non SC car?
1TONY1
Dalton Ga. (Chatt. Tn.)
Actually those were pilots, not drag radials but it does show the ET/MPH theory/fact ;)
1TONY1
Excellent post.
Stock motor, Arrow rockers, headers, exhaust, high flow cats, ET Streets and skinnies, Roe with a 5lb pulley, this was before Roe came out with the Vec..... it had racing fuel but was still pulling out 2.5 degrees of timing across the board with an MSD timing retard.
10.48 @ 136
http://www.streetcarforums.com/videos/viper1048.mpg
Ray W
A great job on the Pilots that day,Tony. Saw they weren't D.R.'s but as you said makes the point.:cool:
Keith maybe should ask where are all those big guns now ? Of the ones still around who are actually happy that they went for over 900hp ?
potterb4
