Found the A/C leak in the black cap..... replace whole aluminum line?
jc411
first off is it a leak or is it where they put in the dye? its been a month or so since they put in the dye and i used the A/C a bunch of times...
do I have to replace the whole line?
the blue cap looks ok but the black upper cap has a big leak in the inside where you can release the pressure...
is it ok to just remove the whole aluminum line while the car is off?
thanks
dave6666
Are you talking about the service taps? Like underneath the colored dust caps?
Like these?
Those are replaceable Schrader valves.
Get the system evacuated, have valves replaced, recharge.
Do it at a service shop that has that equipment.
J
jc411
yea that one!
the one with the black cap!
how do i replace it!
dave6666
yea that one!
Probably the easiest AC fix short of moving to Alaska.
You have to **** the system down. Special equipment needed.
You have to replace the valves. Semi-special equipment needed.
You have to recharge the freon. Semi-special equipment needed.
Go to AC service shop!
jdeft1
Metropolis
Don't just open up the system!!!@ Not only is it illegal to do but you'd end up with two more possible leaks when done! It should be a cheap and quick repair to replace the valve...Most shops have a cool tool that allows the valve replacemnet without evacuation... If you've been adding R-134a for a long period of time the system needs to be totally evacuated and recharged with new freon after the valve is replaced.
J
jc411
ok thanks guys! im sorry it is the valve closer to the driver side...
ill go have the **** the system clean and replace the valve
Mpcc
