Fuel Injector Set, 03-06 Viper & 04-06 SRT-10 Ram, 69 lb/hr @ 55 psi
Sean Roe
Jacksonville, FL
Fuel Injector Set - 03-06 Viper & 04-06 SRT-10 Ram - 69 lb/hr @ 55 psi - Air & Fuel Delivery - Roe Racing
Is your modified GEN3 Viper engine running out of fuel due to small stock fuel injectors? Don't take a chance on running lean and hurting your engine! These high flow fuel injectors are your answer. Great for supercharged, turbo'd and head & cam engines. Direct replacement fit. 69 lb/hr @ 58 psi (stock fuel pressure).
Price: $635.00
Product Details These injectors are sold as a set of 10 and will fit the stock GEN3 Viper fuel rails and intake manifold without any spacers needed. Perfect for that heavily modified engine that needs more fuel than the stock injectors can provide. Features include : Flow rate of 69 lb/hr at stock Viper fuel pressure of 58 psi, 12.5 ohm high resistance (same as the stock injectors), turn on time of 1.14 ms at 14VDC, turn off time of .85 ms at 600KPa, accepts stock fuel injector connectors, 30 degree spray cone utilizing 4 outlet holes for smoother tip-in throttle response, Viton upper & lower o-rings and measures 48mm from end to end (the same as the stock Viper injectors). Picture shows side view and cone with 4 outlet holes.
