Fuel pump for those with a Paxton/Novi and stock Gen3 rotating assembly?
2quik6
Anyone with the Paxton/Novi supercharger setup with a stock Gen3 motor in here? Will only be running 4-5psi, does the fuel pump need to be upgraded if running larger injectors and a new tune for them and the SC ?
I have this setup on my 2005 SRT10 Truck and the stock fuel pump was ok to run with it at 4-5psi, just don't know if the Viper has the same pump or if it can be ran with the Paxton since the boost levels are kept low. Truck puts down 570rwhp/565rwtq with only 4psi and methanol injection.
creese
butler, pa
2quick, bought my 03 a few years ago with a novi 2000 on it already, it had dual electric pumps installed when i got it, running 6lbs boost....dont know if needed, but guessing they are, reach out to paxton, if ur going with bigger injectors, i would most def upgrade your fuel delivery....
Ar Tee Ten
