Gen 1 - installing teamtech harness
viper067
Downingtown, PA
Fairly simple question ... Have all the eyebolts installed except the drivers door bolt which I can't seem to find the hole
So I have to cut the slots in the bulkhead for the belts to pass through, what is the preferred method? Drill and jigsaw? Dremel? Multitool?
I dislike cutting holes in the car and would like the nicest possible outcome
TexasPettey
Austin, Texas
If you are talking about the lower bolt for the belt strap, it's there under the carpet. I'm not in front of my car now, or I'd snap a pic for you.
V
viper067
Downingtown, PA
Found the bolt hole, it was much lower than I expected it to be. Should have just looked where the passenger belt is bolted.
Used a fein multitool to cut the bulkhead and a dremel with grinder tip to clean it up.
Now bring on the track days :) no more spending to much energy holding on instead of driving.
TexasPettey
Austin, Texas
Do you have a racing seat? If not, that's the best combination with a harness. That combination makes a huge difference.
SKY1960
