Gen 3 drag slick choices?
FE 065
MI
I might make the move to a Gen3 coupe soon. I did a search here but didn't see any definitive info on what the easy slick choices are, like whether I can use Gen2 wheels & DRs on a Gen3, or...?
Anyone ?
Volltage
Kenosha, WI
You have to go to a 18" wheel to get any drag tires, and for that to fit on a Gen3 you need to get the E-Brake relcate kit for the 18"s to fit. Only 1 choice for the stock 19"s those are the Hossier R6.
F
FE 065
MI
I already have an extra set of OE '99 rims and BFG DRs. So I guess I'd just need the Ebrake relocate kit to use them on a G3.
Who makes the ebrake relocate kit?
GR8_ASP
You can get it from Parts Rack. Not expensive or difficult to install (once you figure out the orientation).
Good luck. Is this a replacement or addition?
1TONY1
Dalton Ga. (Chatt. Tn.)
I don't think stock gen2 18" wheels will fit even with an e-brake relocate. I believe it will still hit the gen3 caliper. Someone please correct me if I am wrong.
F
FE 065
MI
It's definitely a replacement if it happens at all... :cool:
Then I'll be pestering you for Paxton intall info !
I just was reading on the G2 forum there weren't many red '99 GTSs made. Might be easy to sell my <10K mile GTS come Spring.
tbone96
