Gen 3 parts for sale
xr4racer
These are most of the parts we have left: Gen3 unless noted
valve covers
intake manifold
ecu
T56 driveshaft
pair of new takeoff grey rear calipers
set of Dodge Motorsport alignment plates ( do not have to rely on eccentric bolts to hold alignment anymore), you would need a set of alignment studs, washers and nuts to use these
alternator
starter
new abs hydraulic unit
new master cylinder 5093049AA
new clutch master cylinder assembly
set of used fuel injectors
used throttle bodies
like new carpets from 2006 coupe
Racetech seat #4009whrv from a comp coupe. 25mm wider than standard seat
hydraulic fan ssembly
front bumper cover painted red
Viper truck parts, harness, oil pan, exhaust manifolds etc.
headliner 2006 coupe
carbon fiber pin on gen 4 hood wrapped in red vinyl
Do not hesitate to text or email about any other parts you may need
Please text 330-289-0536
email [email protected]
matt
X
xr4racer
A couple new additions
stock radiator
.027 Cometic head gaskets
the throttle bodies above are stock
matt
wes
League City
Do you have the little plastic pieces that insert into the headliner that cover up the visor bolts. I'm missing one and have been looking for one. Thanks.
Wes
X
xr4racer
valve covers 150/pr
intake manifold 350
ecu
T56 driveshaft 100
pair of new takeoff grey rear calipers 250/pr
set of Dodge Motorsport alignment plates ( do not have to rely on eccentric bolts to hold alignment anymore), you would need a set of alignment studs, washers and nuts to use these, 200
alternator 125
starter 85
new abs hydraulic unit 400
new master cylinder 5093049AA 150
new clutch master cylinder assembly 85
set of used fuel injectors 250
used stock throttle bodies 100
like new carpets from 2006 coupe 250
Racetech seat #4009whrv from a comp coupe. 25mm wider than standard seat 500
hydraulic fan ssembly 200
front bumper cover painted red 350
carbon fiber pin on gen 4 hood wrapped in red vinyl 700
stock radiator 100
.027 Cometic head gasket set 100
matt
X
xr4racer
Still have all of the parts above except the seat. Do not hesitate to make an offer Can ship today.
text 330-289-0536 matt
X
xr4racer
Updated again. Still have the ACRX.
New toe links for the rear 100/pr
ABS sensors
T56 driveshaft 100
Assorted red brake calipers, like new and used 150/pr
set of Dodge Motorsport alignment plates ( do not have to rely on eccentric bolts to hold alignment anymore), you would need a set of Woodhouse alignment studs, washers and nuts to use these, 200
alternator 125
starter 85
stock radiator 100
matt
jpolen21
