Gen 3 upper door panel trim
redtanrt10
Dana Point CA
There isn't an OEM replacement as the trim piece is part of the door panel
A few years ago I recall someone making a replacement trim, look at all the other viper sites as well as facebook.
Stray Cat
Dayton
I need this as well, as well as new Window regulators. Viperstore makes a replacement kit for the regulator that they say works great. I need both sides as neither of my windows drop when the door is opened. Let me know if you find that trim! Thank you!
vertigo
Have a GEN 3. Sent my defective window regulator out to power window repair in AZ. Great people and they did a super job. Took about 10 days and $400 bucks, but better than factor new surplus.
proedge
There's a thread on *** in the classifieds:
"New Reproduction Gen 3 , Gen 4 inner Door Trim ,Improved and More Robust then Factory. Factory Trim has been Discontinued 10 YEARS Ago and Notorious for cracking .
This Trim has Factory Fit and appearance to prevent rattles and squeaks .
$260 each
You can reach me at 416 930 40 FOUR NINE text is best .
Thanks Jay"
Arnold Rod
Sparks, Nevada
Here's what I used on my 2005 Copperhead. I'm very pleased with it,and it does not budge at all. Apply to clean surfaces.
GrimTaquito1972
Hays, NC
I thought the width is 3/4"? I am getting a 2005 soon and I understand at least one side needs to be repaired.
If you want the factory width, yes it’s 3/4”. I’m seeing people put in a full 1” to help close the gap a little or put some extra to space it out. I think you can go either way. I have the 3/4”.
jpolen21
