Gen IV Coupe Stock Alignment Specs?
Stealth
SoCal
Does anyone have the factory OEM Alignment Specs for a Gen IV Coupe? I am changing wheels and tires tomorrow and want to have a baseline.
Thanks!
THEMASH
VA/KSA
Hope this helps, please double check this info first.
ADJUSTMENT FRONT SUSPENSION REAR SUSPENSION
CAMBER
Front: -0.25° ± 0.20° , Rear: -0.65° ± 0.20°
Cross Camber (Maximum side-to-side differential)
F: 0.20° , R: 0.20°
CASTER F: +6.00° ± 0.50° , R: +0.70° ± 0.50°
Cross Caster (Maximum side-to-side differential)
F: 0.30° , R: 0.30°
TOE* (PER WHEEL)
F: +0.07° ± 0.05° , R: + 0.17° ± 0.05°
Note: * Positive (+) is TOE-IN ; Negative (-) is TOE-OUT.
Stealth
SoCal
Thanks!
I leave to pick up the car in a few minutes and will take the specs with me to compare to what they added!
