Gen IV rear bumper "slot": sagging plastic?
rw99
Castro Valley, CA
Has anyone experienced sagging in the boxed regions of the pic below?
On my '09 ACR, that upper border of plastic is dipping down and sagging a bit. Reaching around that upper edge, I can't feel any kind of filler or support material... shouldn't there be something in there to provide form?
Anyone else seen this? Is there any sort of fix... perhaps a support bracket (Mopar, aftermarket)?
Thanks,
Rich
Omaha NE.
They make a Mopar filler kit that fits in these holes and mimics the lower diffuser fins, it is black but can be painted if you wish.
Omaha NE.
Retail pricing is $252 and they are still availible through Dodge.
dester243
If that's your green viper, the left (driver's side tire) is on backwards....
F
FrgMstr
Guest
The previous owner put these on my car. Have never had issue with these.
These however will not "line up" with the multiple diffusers on your car. Not sure if these would look "right" or not.
$219 at VPA.
PeterMJ
The right piece does not fit too well, unless my eyes fail me, there is a big gap on top of that piece...
PeterMJ
Then you should make some, seems like a great opportunity right here. IMO, there should be a version with the mesh instead of bars not to worry about lining them up with rakes on the diffuser. CF inserts with black mesh would look very cool.
I have a bunch of those in stock,
but they are only made for converts ,
there is no Coupe version out right now
Coloviper
Colorado
Just get a longer piece of strong aluminum bar and put on underside of ground effects with double sided 3M tape, behind the ground effects hidden. It creates a bridge and pulls up the sag. Saleen owners have been using this trick for years.
R
rw99
Castro Valley, CA
Steve, is it possible to modify (cut down) the convert piece to fit a coupe? Or are the convert slots LARGER than the coupe's?
Thanks,
Rich
rlamorte
