Gen1 o-ring specs ps reservoir to ps pump?
Chuckster
Roswell, GA
1994 that is leaking ps fluid from bottom of reservoir. Cannot seem to find the specs on correct replacement o-ring and expect the one that in there to be deformed. Does anyone know what size o-ring this is? It’d be nice to have one on hand when I take the reservoir off. Thanks!!!!
Chuckster
Chuckster
Roswell, GA
Thanks! I’m trying to search all over online. Maybe that will be easier bc it’s more common.
Keep in mind that you MAY need a new P/S reservoir as it was not uncommon to cause a crack in it when removing the lines to service/flush. This problem led to the publicized "turkey baister" technique of sectioning our the reservoir
followed by fillings, cycling the P/S, refill (total of 3-4 times) to achieve a 95% clean fluid result.
I recently replaced my 26 year old reservoir. Despite a fresh pump inspection and reseal, it kept leaking. Turns out the reservoir was leaking from the plastic seam welds.
Chuckster
Chuckster
Roswell, GA
Yeah…I realize that is a possibility and may do that as well. Thanks !
Chuckster
Chuckster
Roswell, GA
I plan to take it off and inspect it closely for sure. It is an almost 30 year old car!
Drock187
