GEN1 Oil Consumtion ??
Much
Austria
Hello
I just want to ask how much oil your cars Need ???
I needed 4 Liters for 9000 km , thats about 1 Gallon on 5600 Miles
I think thats a lot :crazy2:
But there is no Oil araund the headGasket or in the coolant
Iam using the Original SRT10 Oil
What could be the Problem ???
Greetings from Austia
Mike
mad prof
Mike, it seems a lot of oil getting burned, if not leaking out of the engine. Do you see any blue smoke out of the exhaust or do you smell any oil? I suspect not, otherwise you should have mentioned it. Is your oil too thin? What viscosity is your oil brand?
It would be a good idea to do a compression test to see the state of the piston rings.
I have a 1996 RT10 and the oil consumption is negligible. I use Shell 15-40 Synthetic oil.
Alles Klad
Mad prof
bluesrt
could be bad valve guides? let it sit and idle for about 15 minutes, then give it a few revs and see if alot of blue smokes rolls out of exhaust, usually on a bad ring, it will foul the spark plug
Much
Much
Austria
I change the Oil every 2 Years , about every 6500 Miles .
I use the Original Mobile 0W40 Oil for Srt/10
Car is a 94
Problem is i cant start the car at this time because the intake manifold is off the car, but that is the first thing i try when the car is back togehter
Only thing i realize when i drive the car in summer is , that i smell sometimes some burning oil.
Btw car is not stock , it has about 512HP
Thanks for the help so far
Mike
plumcrazy
ALL OVER
HP should not matter for oil consumption. might want to try a much heavier oil and see what happens
Much
Much
Austria
Little Update
Did a compression test today , This are the results
Passenger Side / Driver Side
55 PSi 100 PSI
85 PSI 65 PSI
50 PSI 50 PSI
80 PSI 70 PSI
125 PSI 55 PSI
I think there is something wrong
Did the test with cold Motor and the Intake off
Much
Much
Austria
Do you think i should made another compressione test with warm motor ?
The car stand for about 2 1/2 months now , without starting the motor. Could this cause this bad reslult ??
Mike
bluesrt
that is the strangest compression test i have seen to date
Much
Much
Austria
i thougt the same , thats a very strange result . Is there anything i could have made wrong ??
bluesrt
do a cold test with intake on and when you test each cylinder, hold the throttle wide open for accurate reading
SoCal Rebell
Mission Hills, Ca USA
I burned about a quart every 175 miles in my 2000 Gen 2, turns out it was the cylinder wall issue and I had to send it to Arrow for 9 weeks for a complete rebuild.
Much
Much
Austria
Made a second Compression test Today
Put the intake back on and let the Motor idle for about 20 minutes yesterday.
There was no blue smoke from the exhaust , and the spark plugs look good.
The Results where :
140 PSi 135 PSI
135 PSI 140 PSI
135 PSI 140 PSI
135 PSI 135 PSI
135 PSI 135 PSI
I think this result is much Better :D
I think there was something wrong at the first test
Maybe it was too cold ( we have -11 grad here in Austria)
Much
Much
Austria
I think i try 20w-50 or the liqui moly 10w-60 Oil next Year and see what happens
No members online now.
TheHunter
