Getting upgrades 2000 RT/10
Kebin F Friel
I have a steel gray 2000 RT/10 25,000 miles (not sure how many were made in gray) but getting upgrades part finally in. Just baught a few months ago.
New Ball Joints
Belanger Complete Exhaust
K & N Performance Air Intake
SCT X3 Power Flash Programmers
Dyno Tuning
Dropping off Friday cant wait. Any suggestions for the next upgrades. Just found a soft top w/ frame. Need new wheels and tires.
BadBrad72
They are one of the rare colours.
I have one up here in Canada that colour.
Fidanza light weight flywheel with replaceable friction discs made the car rev up faster. Noticed a big difference with it. quick question. Did you replace all ball studs upper ad lower front and rear. Not having much luck looking for them as I can only find replace the whole control arm. If it was, say Mood. What part numbers
Kebin F Friel
Kebin F Friel
BadBrad72
Part numbers I have are for the
upper and lower control arm energy bushing kit 22310 (1) $110.08
Front Upper Ball Joint 22310 (2) $81.65
Front Lower Ball Joint 22308 (2) $82.80
ARD Mortor Sports
Lawrenceville, GA
770-965-2322
BadBrad72
Thank you! Greatly appreciated.
MrLighty
Ipsco power steering pulley and bracket. Polyurethane motor and transmission mounts. Replace all suspension bushings with polyurethane. Coil over adjustable shocks. Shift eliminator kit. Short throw shifter. Paint correction.
Kebin F Friel
Kebin F Friel
Bad Brad, you have my twin. I just scored a soft top with a frame.
MrLightly thank you for the input. Just had the suspension bushing replaced. Adj Coilover is next.
Here are my Dyno results.
New Ball Joints
Dyno Tuning
Kebin F Friel
Kebin F Friel
More upgrades
Thank you JonB at viper parts rack for hooking me up w new
wheels and tires it drives fantastic
usmcfieldmp
Fort Worth, TX
Nice, those wheels are a really good look for the car.
Your rotors caught my eye; you should check to see if your rotors are directional (internal vanes). A lot of manufactures tend to make them with the slots meant to sweep forward. Having them flipped won't make them explode, but if you drive canyon roads, autocross, etc - they will heat soak/overheat faster.
The drilled and slotted rotors on my Audi were directional. Passenger Front... front of the car to the right of the picture.
Kebin F Friel
Kebin F Friel
Thank you I will check they came on the car when I got it have not looked that close. Bit I will
xeng yang
