grrrrrrrr code p0340 wont start
tmr4479
******* Ga
Car wont crank when hot. Ive already installed new cam and crank sensors about a year ago. Anything else I should look for, or just try new sensors? I did install a svs shifter and MGW knob today while its on my lift, seems to shift pretty nice. Only if I could get it started again to go drive it lol.
Ulysses
San Diego, CA. USA
Inspect the connector pins and plug. Make sure that nothing is broken in the connector and that the pins are clean. If all looks well, inspect/test the wiring from connector to PCM. Could be anything from the sensor to the PCM.
T
tmr4479
******* Ga
ok ill try checking the plugs, the thing that gets me is it will start fine when its cold.
Ulysses
San Diego, CA. USA
Expansion/contraction of contact pins? PCM degradation such that electronics no longer function at hot? Could be, but a good diagnosis of the complete system will reveal.
T
tmr4479
******* Ga
well i just went ahead and ordered new cam and crank sensors and the engine harness
ctrengine
