hard shifting problem
srcsrt10
was out driving today and found it hard to shift between first and second after setting at a traffic lite ? it was extremely hot out (over 90 deg) if that helps, but after rolling along and other short stop and go's it shifted fine. never had any trouble before ! any help would be greatly appreciated !!!
Mutts02GTS
Plymouth, Wisconsin
Were you around the shift threshold where the skip shift eliminator works? Up to 14 mph I believe. What year and model car? Mileage on car?
srcsrt10
my car is a 2003 with 9500 miles. cant remeber my speed though. thanks for the quick reply !!!
DeceptioN
Spring Hill, FL
Probably skip shift, it is from around 10 mph to 20 mph. It is kinda ******** but can be fixed for relatively cheap with a skip shift eliminator that you just plug in.
Omaha NE.
Check your clutch fluid condition, once it gets that hot sitting in traffic over time the fluid breaks down and if there is moisture because it is old you can get air bubbling and bad clutch action.
swexlin
West Chester, PA
At my last service last month, I had the clutch fluid changed out on my 25,500 mile car, of which I'm the 3rd owner. I've never had any issues, but since I don't know how it was driven before me, I figured good preventive. My tech told me after that it was indeed a good idea, as the old clutch fluid looked kinda iffy.
So, agree, might check it and change it.
gb66gth
Big-D
I hated the skip shift. That was the first thing I did to my Gen IV, was get rid of that feature
ctrengine
