Hard to start when cold! Help!
benson8708
When my 1995 rt/10 is cold it take about ten seconds to start. I have removed and cleaned the throttle body and it didn't help. I have readjusted my throttle cables. I am thinking maybe fuel filter but it runs great once it starts. Please advise.
Mike
plumcrazy
ALL OVER
did you try some of the other obvious easy things like : plugs, wires ? and also the fuel filter. if not, id change all of those regardless if they're old
B
benson8708
Yeah I need to check the plugs. I heard the wires are a pain to change.
SNKEBIT
western wisc.
I would say your fuel pressure reg. has croaked. Try cycling the key to run pos. 3-4 times then crank the engine over. If it starts right away, regulator is bad, need to pull the tank out..............fun,,,,, NOT!
B
benson8708
I turned the key a few times and then it started right up. Thanks guys. I will try and figure out how to fix the fuel pressure regulator. Any merchants chim in if you have one.
SNKEBIT
western wisc.
You can still buy them from Dodge seperately, I think. (you can still buy fuel pump seperate.) The gen.2 guys are screwed.
