Has anyone change springs?
8mywal8
Has anyone change rear springs on there Motons by just taking the top bolt out? Is this possible?
Omaha NE.
Yes you can without too much trouble. To make it easy the rebound should be full stiff and compression full soft. That way you can push the rod down easy and it will come up very slow giving you time to work the springs in or out. :2tu:
