Has anyone installed the K&N intake for Gen 4?
FLX109
Massachusetts
Just wondering how it looks and if anyone has had problems with it, also if someone can post pictures installed?
thanks
FLX109
SilveRT8
Boucherville, Quebec, Canada
JonB,
Should I also get 2 'Drycharger'air filter wraps, in the event that I have to ride in the rain one day, as it happenned a few times on scheduled VCA meetings last summer.
Red would look good, I'll give you a call.
SR
S Cal
I just installed the K&N cold air intake. It is pretty simple to install and took about 2 hrs to do it at home (need a screw driver and a wrench).
It does look great, but I do not notice ANY change in power or sound. I have not done a before and after dyno. I will be doing a dyno after I install my headers.
It is much heavier than the stock intake. It weights 17.4 pounds (per package insert); stock air intake weights 7.5 lbs.
For the price, I do not recommend doing this modification. If you like the look of it, then go for it.
THEMASH
VA/KSA
I just dynod the drop in K&N filter, lost 2 whp... but not the newer cold air intake kit.
PaViper
WOW 10 pounds heavier doesn't sound like a very good mod to me:omg:
Nader
New York
He lost two horsepower but as you mentioned that could simply be a result of heat. I dynoed my car and lost 12 between second the third run.
2whp....could that be considered dyno standard deviation. 2whp seems rather insignificant.
MbnViper
i installed K&N filters and gained about 6rwhp.
any green filters for Gen4 ?
THEMASH
VA/KSA
2 whp less at peak, and 6 whp less in the mid range. car ran richer by 0.3 (11.2 stock Vs 10.9 K&N)
I dynod the viper 3 times, got same power # (531 and 530), installed the filter while on the dyno, took 3 min, the car cooled down more then it did between the first runs, ran it again 2 more times, got the 2 whp lower and 6-8 whp in the mid range (528s).
The car ran richer, so it will have to lose power on an NA engine i guess.
I did leave it on.... will drive the car around some and try again. as i did not give the ECU any time to re-learn, not even sure if it will make a difference. We will see..
KN will tell you, the Typhoon and FIPK kits achieve their HP when the car is in motion. So a static dyno run with a floor fan cannot duplicate any force-feed of airvlow into the airbox.
ie when the G4 kt was first tested at a well-respected 1992-2010 tuner, the HP was very real...until the hood was closed. ****. Gone.
$525 VCA
$500 Venom
THANKS
F
FLX109
Massachusetts
$525 VCA
$500 Venom
THANKS
Wouldn't this have the same effect even with the stock box especially since it is a ram-air style air box?
MbnViper
the stock system is efficient enough i believe.
a drop-in K&N or Green Filter (may try this next) will do best IMHO.
FLL-B/W-GTS
Have K&N drop in filter on Gen 4 for 6 months.Works great,no problems at all.I will get one for the ZR1 when K&N put one out.
2008 Viper Coupe
2009 Corvette ZR1
bluesrt
you really cannot trip the factory airbox i believe,its a true ram air.how could it get better.......
JonB,
Should I also get 2 'Drycharger'air filter wraps, in the event that I have to ride in the rain one day, as it happenned a few times on scheduled VCA meetings last summer. Red would look good, I'll give you a call.
We include a set!
Factually, **** Sells. This Aluminum box is as much a dress-up item as a HP adder. If you can feel 12 HP on top of 605, you have a better butt that I. K+N claims the HP, and respected dynos have proven it in static tests....hood open.
[Dozens of customers have bought the off-brand Gen 1-2 "Hot Air Induction Kits" with their **** cones, despite our warnings of HP LOSS. We WONT sell those.....] but the G3 and G4 K+N is a valid upgrade on 2 counts.... but dont bet your pink slip!
F
FLX109
Massachusetts
Well I did it, installed it and we will see what happens it was a easy install and have all stock parts so I can go back if needed.
here is a couple of pictures:
GreatWhiteKAC
