Header ?'s
carguy07
Cuyahoga Falls, OH, USA
Header ?\'s
How much noise do you pick up when you put headers on? What causes it? Guessing resonance from the pipes or thinner pipes. I have a GEN I with stock cast manifolds.
Are stock manifolds GEN I or GEN II a significant bottleneck? Looking to do a Roe blower soon, but by no means the ultimate build up. I will sacrifice 10-20 hp all day to save expense and noise.
Any thoughts on a mild port job for the heads? HP vs Expense for a street only car.
Thanks..KW
hemibeep
Tampa FL
Re: Header ?\'s
I have just left on the factory manifolds with heat shields. Don't think noise would be a problem, but it would raise heat(ceramic coating helps). I too am staying "cheap" on exhaust for now only going high flow cats and catback....more for good sound and lower sill temps.
For the street porting, probably a waste of $$$. If the wrong person does the work, it will hurt an otherwise stock motor....i.e. loss of port velocity.
I would and will do the headers with the ROE.
Casey
Valparaiso, IN.
Re: Header ?\'s
Thanks..KW
Headers do not produce NOISE! They produce MUSIC, awesome Muscle Car Music!! :2tu:
Jack B
NE Ohio
Re: Header ?\'s
If you take a look at a dyno curve, those cars without headers tend to have a torque curve that drops much quicker than a car with headers. No matter what you do to the engine the headers are going to help the other mod. Headers without cats could be worth 30-40 hp, depending on the car. The later model Gen2's don't seem to gain as much as the Gen1's and early Gen2's.
2BADD 4U
N.E. Pennsylvania
Re: Header ?\'s
Originally I had filters ,tubes and a corsa cat back.....I added belanger headers and rt ceramic high flow cats....I wish I did it sooner....better and more throttle response, very quiet on the highway when cruising.....you can carry on a conversation or play cd's...NO droning at all.
But when you get on it , especially in 1st gear...the sound is awesome! like a funny car....It is a personal preference...but I would actually like it louder...the headers are not that loud under normal driving....they make the Viper sound like it should!
Dave
N CHARG
Dallas
Re: Header ?\'s
I have the same setup as 2BADD 4U... except I left the side seal mufflers out. I completely agree with him. When you get on it, everyone clears out, when you hit cruising speed I don't think it is any louder than stock. No drone... I did add smooth tubes and RedLine filters and removed the airbox. I have a small whistle when I accellerate... don't like it, but livable. I will probably chase down the whistle and correct the problem.
rcdice
Columbus, OH
Re: Header ?\'s
NCHARG,
Whistle is the high flow filters. Drove me nuts at first. Now I just consider it the snake Hissssssssssing. :headbang:
venomblue550
Re: Header ?\'s
still no one want the set of brand new borla headers for cheap price?? come on?
Neil - UK
ENGLAND
Re: Header ?\'s
check out JonB's/Partsrack belanger (fantastic headers) sale in the suppliers forum, great price, our region is doing a group buy :2tu:
SKY1960
