Help my bladder won't hold......
DrDJ
Chesapeake, Virginia
Help my bladder won\'t hold......
...AIR...driver's seat, not good for my back. Any suggestions on finding the leak and repairing it? My warranty ran out last month.
DrDJ
monnieh
Colleyville TEXAS
Re: Help my bladder won\'t hold......
Mine would not either, got the entire rear part of the seat replaced.
The new one does the same thing!
My 97 did the same thing.
Asp Man
Kelowna B.C., WEStern Canada
Only thing I can suggest is to pull the seat, 4 bolts, 2 screws, so you can gain easy access to all areas.
Put it in a quite room, pump the bulb up and listen carefully.
If it's leaking at the valve where the bulb is try snipping a bit off the line and re-attaching with new zip tie. If the bulb itself is hissing you can replace it for about 7 or 8 bucks at a medical supply place. It's the very same as a squeze bulb for a blood pressure cuff. (though you may need to pull the one-way valve out of the new one and stick it in the other end for true stock appearance, to go even further, use the original one way from the old bulb which has a slightly different appearance.)
Hope this helped.
bth1
New Jersey (Union County)
I would think that once you take the seat out you could probably use a little water around the seams to see if it bubbles once it is pumped up.
tonychicken
