Okay,
I've been reading on the Viperboard about oil leaks and power steering leaks. Some of these leaks have caused fires like this post here: http://vca1.viperclub.org/ubb/Forum14/HTML/010002.html
I have this leak coming somewhere from the driver's side left throttle body. I have this sensor I suspect may be leaking, but not quite sure. Look at pic below. What is this sensor? It has something to do with oil. I pulled it out and there was oil in the hole. Is it common for this to leak?
Below is a picture of another place I suspect may be leaking. The power steering hose to the steering rack. If it's leaking from here, then it would be from the top side because it's soaking the front top driver's side part of the engine.
I pulled the power steering cap off and the fluid level is very low.
My problem is that I'm having a hard time if it's the power steering hose or something else from the top end of the engine that is leaking. I did noticed that I had a small puddle of oil under the intake plenum. This could be cause by the oil getting pushed back from the front while driving.
I cleaned the oil up from the front with some carb cleaner and was careful not to get the red paint sprayed on. I turned on the car and let it run for a while. Nothing leaked. I took the car out for a 2 mile spin and when I parked it again, there was oil all over the front of the leftside of the engine. I can't tell it's power steering fluid or engine oil. They both have about the same color.
Is there a way to find out which is which? Any idea's for me? This stuff is covered under my warranty, but I can't get my dealer to fix it with out a bunch of excuses. I don't know why I bought an extended warranty. It hasn't done me any good.
I have to fight my dealer to get work done. Now I'm afraid to take it there cause I'm afraid the tech has an attitude towards me now. He might break something by purpose, I'm not sure. I guess I'm stuck fixing it myself. They had the car sitting for 3 weeks doing nothing while they fixed other cars that came in after I came in on a scheduled appointment!
I'm mad about this, but there's nothing I can do. I got no support on this stuff from anyone...just excuses. but anyways..don't want to ramble...any suggestions would help! I'm afraid my car is going to catch on fire if it's not fixed. Does warranty cover engine fire?
Thanks in advance.
]Below is a picture of another place I suspect may be leaking. The power steering hose to the steering rack. If it's leaking from here, then it would be from the top side because it's soaking the front top driver's side part of the engine.
Thanks in advance.
