Hi Bill,
Wait until Monday to call? Heck, I don't have the luxury of taking a day off. You can call the shop anytime.
In rare case where I'm not here, my mobile # is on the answering machine and I keep it on when at home.
If you need a walk through on the install to make sure it's OK, call me here at the shop (904) 733-5469 or on mobile at 904-535-4949. It's about 5:30 pmSunday afternoon and I'll be leaving in the next 1/2 hour.
Just a quick tip, with all the connections made, jump the two wires on the temperature sensor with a pair of needle nose pliers. If the fan comes on, you're good to go. If not, check your connections. Double check the gray wire connection (it's ground - with the engine off, is small in size and and is solid gray with no other markings).
