HELP with VEC2 installation and tuning Houston area
beckertb
Beaumont, TX
Greetings everyone. The title pretty much says it all. We added a VEC2 to my Heffner SC'd '97 RT/10, bigger fuel pump and now despite help from Sean (many thanks for your help), we can't figure it out. Forget rolling it over to the dyno to tune it, I mean we can barely get it to start. I NEED HELP. Anyone near Beaumont, TX? (100 miles east of Houston)
Frustrated more than you can imagine,
Ben
409 659 0953
Sean Roe
Jacksonville, FL
Ben,
Was this post before or after I talked with you this morning?
Is everything going ok?
The 61% fuel trim value should be correct for the injectors you have at 55 psi fuel pressure. Any different pressure will change that calculation.
Call on mobil if needed. I'm home for the rest of the day taking care of neglected yardwork.
Regards,
Sean
B
beckertb
Beaumont, TX
Sean,
This was before. I got the fuel pressure in better shape. My fuel curve looks good. My timing needs some adjustment and some fine tuning, but with the centrifugal blower vs the (+) pressure blower the boost curves are a bit different. I tried to call, but went to voice mail. I do appreciate all of your help.
Thanks again,
Ben
