high idle
tricky nicky
new jersey
just picked up a 2001 gts and ive noticed when i put the car into neutral while rolling the idle stays between 1500-1250 rpm until i drop below 20 mph, then it returns to about 700, is this normal?
eucharistos
Houston
congrats on your new viper :drive:
no not normal in that it should not happen :eater:
yes normal in that is is a common issue :omg:
look at these:
http://forums.viperclub.org/threads/634078-high-idle-help
http://forums.viperclub.org/threads/572612-Random-High-Idle-Sticking-Idle-lt-master-thread-gt
http://forums.viperclub.org/threads/542933-2000-GTS-High-idle
http://forums.viperclub.org/threads/542902-High-Idle
if you search you will find other threads on the issue
i have been living with mine for quite a while, and will fix it someday, but it is, like yours, the "good" kind of high idle - the kind that goes down when below xx mph.
peace
DrumrBoy
GA
Its been so long since mine operated without the AEM that its hard to remember, but I think stock PCM's hold revs high until you come close to stopping and then drops down. This helps keep revs up in case you're just looking for a gear....good for autoX and road racing....and spirited on-ramp activity. Can't remember how high is too high, but I think that overall dynamic is correct though.
shibbydude
