viper spray
The little painted screw just angers the coumputer and creates idle hang when I screw it in , so I set it back to stock. the set screws at the base of the throttle bodies would likely do they same. My car idles fine untill I run the A/C , then it surges down a tad too low when I stop at a light with the clutch in. It will almost die or will die every once in a while while running the AC. I did the new battery thing and may slap in a new 02 sensor if that will help. I have the Mopar Perf. computer. ?????????????????
