How do 18" BFG drag radials hook on the street?
RedGTS
Tennessee
How do 18\" BFG drag radials hook on the street?
I'm looking for some more traction, and I've read a lot of good things about the new BFG 18" 345/30/18 drag radial, but most of the reports seem to come from track use at well under 20 psi tire pressure. My question is how much do they improve traction over Pilots at a streetable (28-32?) tire pressure?
sun diego
Re: How do 18\" BFG drag radials hook on the street?
I've got them in 17" on extra rims for the strip. I've driven them on the street and they hook up great, even with nitrous. They corner badly, to the point it is more a straight line car. The Kumhos are probably a better dual use tire.
Fishtail
PA
Re: How do 18
I've got them on my DLM car. I like them a lot. A little wheelspin in the cooler weather but DEFINITELY better than stock!!! It gave me the edge over the race with the zo6 :laugh: . They don't corner too well though :p .
-Lou
R
RedGTS
Tennessee
Re: How do 18
Which Kumho are you talking about, and does it come in 18 or only 17?
Lou, I'd say that 800+ hp gave you a little edge too! :)
Larry Macedo
Sanford, FL
Re: How do 18
Ronnie,
If your looking to use these tires mostly for street purposes, I'd recommend the Kumho V700. Unfortunately, looking at the TireRack catalog, the largest is in 17" and your Viper is on 18's. For your car I'd recommend the BFG or the Hoosier R3SO3. Give me a buzz when you get a spare moment.
Moundir
Ny
Re: How do 18
If you drive your car in the rain at all you will poop your pants with the drag radials :eek: For a kick A$$ street tire that outgrips,outhandles and outlasts the Khumos check out the michelin pilot cups. Expensive but well worth it, they also come in 345s on 18" rim ;)
R
RedGTS
Tennessee
Re: How do 18
I don't drive in the rain, so that's not a problem. The real problem (and the reason I don't already have the BFG's) is that I've got 19" wheels and I hate to give them up. :(
Snake Bitten
Southern Kalifornia
Re: How do 18
Did you get these on yet???
jcaspar1
Sacramento, CA
Did you mount them using 10" front wheels?
sun diego
I just put them on the back and kept stock front tires. Bad move?
8AVETTE
Shelby Twp., MI USA
Re: How do 18
I have the front and rears on my ACR. They are two months old and have 700 miles on them and are now ready for the trash. My DLM level 3 of only about 3 weeks have destroyed them in 3rd gear. Thanks Doug, Ha Ha.But I must say they are much better than stock.
V10 MOJO
Youngstown, Ohio
Re: How do 18
they drive just fine and hook damn good if psi is right. only question i wonder is how many street miles are they good for???
TomMiriViper
S.Miami,FL,USA
Re: How do 18
:eek: you poor soul :laugh:
MaxedGTS
Ohio
Re: How do 18
Spinning BFG's in 3rd gear??? :eek: :eek: lol you need slicks to drive that on the street. :cool:
Max
jcaspar1
Sacramento, CA
Sun Diego,
I guess my question is what size are you running and on what size wheels. The largest size I see the 17" coming in is 315 which is too small for a 13" rim and too big for a 10" rim. The next size is 275 which would fit fine on the front 10" rims used on the rear. The 18" come in 345 which is about perfect for 13" rims.
sun diego
I have 315 on the back 13", and 285 Michelins on the front 10". What is a better rear tire for the 13" for the drag strip?
jcaspar1
Sacramento, CA
Re: How do 18
I don't think there is one. The Nitto 555R comes in the same sizes. I had heard that the 13" rears were too wide to mount 315's on but am glad to hear that they are working for you. I may try that set up also.
FE 065
MI
Re: How do 18
I had my 17" BFGs on front 10" rims, a friend had his on rear 13" rims. Didn't seem to make any difference when we were both at the strip together. Doesn't seem like anything to worry about..
Jack B
NE Ohio
Re: How do 18
Keep the Nitto's on the 10" wheels. Logical points to a sealing and safety issue on 13" wheels.
