An electronics **** might be able to use another injector driver as a signal, not an amp draw, to trigger a ground switch of the same duration. It means injector 7 would always do whatever injector 3 did (or whatever you pick) but just fractionally later. Believe it or not, I think injectors are intended to fire at closed valves because the sudden blowback upon intake valve opening and then rush into the cylinder provides better fuel-air mixing that shooting through an open valve. So your target timing can be slightly off from OEM and still run fine. It already gets the 12V, so it's just a switch. Sounds so simple to a mechanical engineer, huh?
