I heard a bang!!! Oh-NOOOO
Mighty GTS
Bucks County, PA
Yesterday I was out in my new to me 97 GTS. I recently had the cars to tator's and got all my fluids changed and everything checked out. Yesterday,
I was hotdogging and hit it from a roll in first gear, tacked to 5K and nailed
second. When I hit second, where there should have been a chirp, there was
a bang in the rear, First thought was the spare was loose and banged against the well, second thought was, I broke a shaft in the back, but the car is
driving perfectly and I continued on my journey. I drove it today and everything seems fine. Any ideas.....IT was a loud BANG!.....But everything
seems A.O.K. Thanks, Joe.
jimandela
Western New York, USA
did you have the rear end fluid changed when you changed fluids?
Might be a good idea to change it if you didn't... might be the gears ?
at least it is still running okay....
M
Mighty GTS
Bucks County, PA
Yes, I had the rear fluid changed also. I'm sure the right fluid was
added and also the additive. It was Tator's so I have no worries..
SapphireGTS
Columbus Ohio
my 2001 has done that whith an agressive downshift. I never worry until sonething doesnt drive right. The viper makes lots ofnoises. It could have been your exhaust flexing and hitting the bottom of the car.
M
Mighty GTS
Bucks County, PA
Yes the recalls been done. Chuck checked it AOK. I really am liking the
wheel hop answer. I am a newbie and unfamiliar with all the car's quirks
so far. But, Man I love it......
Bad_Byte
Corpus Christi Tx
I believe you briefly broke the sound barrier. It happens often. You'll get used to it. :D
OK OK I can't resist being just a bit of a smart asp.
TOOOFST
Barrington,il
Several headers hit the frame,my balengers hit on pass side,Hard downshift(rarely do)and sometimes hard 2nd i'll hear a bang that scare the crome off a trailer hitch.Gonna try changing out the motor mounts!
Snake Bitten
Southern Kalifornia
TOOOFST and SapphireGTS...Drivers side motor mount is the culpret...not the bracket, or the heat shield...
Here's the left side part number: 4642617
Lists for $46.20
Left side (drivers side) of motor raises under load and tears the insulator portion of the mount...allowing enough play for the header to hit the frame...The one I replaced last year...
Cape Coral, FL
my car did that crap ONCE, but could never get it to repeat. I inspected it until I was pulling my hair out, never found the cause.
Snake Bitten
Southern Kalifornia
The front or the rear "bang"??? You cannot see this tear (front bang) unless you remove the mount...It's cake if you are on a lift...
Cape Coral, FL
no, mine was definatly in the rear of the car, about directly below the glovebox-(diff/half-shaft area)
