I'll be Dynoing my 98 GTS on 4/24. Any tips?
DrDJ
Chesapeake, Virginia
I\'ll be Dynoing my 98 GTS on 4/24. Any tips?
Anything to check to make sure it's done right? What #s should I expect? Current performance mods...Smoothies, K&Ns, Jesel rockers, hardened pushrods, VEC2, RT high flo cats, 2 1/2" Corsa, and "Hybrid" emblem. I'll be forwarding the results to Roe racing.
DrDJ
Dave T (BADVENM)
Goodland, KS
Re: I\'ll be Dynoing my 98 GTS on 4/24. Any tips?
Use 4th gear for the pull. I couldnt speculate on the numbers. Is it a dynojet or mustang dyno...that will make a difference (mustang typically lower).
RedEnuf93
Lancaster, PA
If it's a Dynojet, maybe 390-420HP, TQ numbers are higher than HP numbers.
Dave's right, take it to 4th gear and hit it. You will not make any HP/TQ after 6000RPM, so dont hit the rev limiter.
My numbers were dropping significantly at 5500.
Hybrid emblem should be good for extra 15Hp above the Dynojet numbers! :2tu:
Dave T (BADVENM)
Goodland, KS
The starting rpm in 4th gear should be around 2000-2500 or so. Like RedEnuf said, no need to take it to 6K rpm. Have someone monitor the a/f during the run. My only attempt in my GTS after some mods and a piggyback computer caught the eye of the dyno operator and he had me shut it down. My SRT Ram on the other hand threw a rod with no warning.
Oldwilsonian
Just installed a Dynajet 248x Dynamometer in my shop, my '02 GTS ran 424 hp, & 460 torque.
As one member posted 4th. gear between 2000 -2500. Good luck.
Anyone in the Tampa Bay area interested in Dynoing their car please call - Dominic 727-848-3700.
