Installing Penske Coilovers and 19"/20" Rims, Advice on Ride Height?
01GTS
Bay Area, CA
From what I've read I should lower the car 1.5" in the front and 1.25" in the rear. The Penske suspension will be finished being installed on my car tomorrow and want to make all the necessary adjustments. It will be running on 19"/20" wheels. Am I correct in lowering it 1.5" in the front and 1.25" in the rear for best "look and performance"? These parts are going on my 2008 Coupe.
Omaha NE.
The thing will be SLAMMED and probably rub everywhere, 7/8" plus the settling that the springs will do should be more than enough if you want the performance also and not rubbing everywhere.
IMHO
01GTS
Bay Area, CA
Definitely don't want to deal with any rubbing. I will try 7/8" to start. Thanks for the advice.
SFViper
San Francisco
I lowered my car just 1/2" after installing the Penske 8300 coilovers and it handles great with no rubbing or scraping on my driveway.
Shank2117
rubbing aint a problem. scrapping probably will.
You just gotta learn how to go up and down driveways/bumps when your slammed.
I think you would do the the 1.25 in the front, 1" in the rear.
Guy
Europe
What tires do you have on there? Someone correct me if I'm wrong, but if you have the same offset as stock, same overall tire widths and diamteters.. then the 19/20 should be exactly the same as the 18/19 setup as far as to how much you can safely lower the car.. right?
dave6666
My 20" PS2 rears are 28" OD. The factory 19" PS2 is 27.2" OD. So there's another 3/8" or so of rub just in the tires, unless you go to a Pirelli 25 profile.
Nader
New York
I think it depends on the profile. I run Pirellis with a 25 profile and they are about 1/8 shorter than stock.
webironmongery
