I've been Striped!!!!!
ViperTony
:omg: I just couldn't resist adding black Vinyl stripes to my '01 RT/10. I loved the clean look when I originally got the Viper but I wanted a little extra something...and after seeing pics of Baz's stripes on his yellow Viper I was hooked. Baz...you were my inspiration on this one.
Adding Vinyl stripes has been discussed, written and the how-to in the Illustrated's section was a big help. I'm not going to write this one up but I will share some tips and/or frustrations here. This was a fun a process but I WILL NEVER DO IT AGAIN. :D Why? Adding stripes requires patience. Being Italian...well I have no patience so I already knew this was going to be a challenge.
Material: I purchased my vinyl stripes from VinylStriping.com. Yes, a regular sign company. I purchased Avery A9 2mil, 9 year outdoor-life cast vinyl. In fact, they sold me a 150 foot roll. I think I have enough Vinyl leftover for 4 more vipers. They were easy to do business with and they pre-cut the Vinyl to an 8" width. 8" stripes with a 4" separation. For the record, I did email JonB at Partsrack to check if he sold vinyl kits but he doesn't. In this case, less than 50% of all advertising wasn't wasted. In fact, JonB said call a sign company. I did. I tried to support our great sponsors here but Vinyl doesn't seem to be a big seller for them. Once I received it all I had to do was install it :rolleyes:.
Unfortunately, there's quite a bit of shadow in these pics. I took some quick pics today while the sun was out but shadowing is skewing the perfection (well almost) of these stripes. I'll take better pics tomorrow. Maybe some photography lessons are in order:
BEFORE:
AFTER:
I also have a 150 foot roll of Avery A4 3mil vinyl. However, I found that the 2mil was much easier to work with especially within the license plate and naca duct areas which were a chore to get done properly. The 2mil will stretch and narrow if you pull on it too much. Simple don't pull on it too hard...problem solved. When installed, both will have ridge on the paint since it sits on top of the paint and is 2mil thick...I find any difference in ridge thickness between the 2mil and 3mil. If the ridge bothers you...paint them on.
Why Vinyl Stripes: It's reversible. Even though the vinyl is 2mil, it will come off but you need to use heat. Hair dryer, heat gun or the sun works fine. Someday I may have them permanently painted on but I wanted to be certain I would like the look. I freakin' love it. :D
Preparation: The area on which you're applying vinyl must clean. If its not clean, every piece of dust, dirt, contamination will show up as little pimples under your vinyl. You never get them out once you lay down your vinyl and they will stick to the vinyl. Don't ask me how I know about this. :crazy2: I was the areas on which I was going to apply stripes using an extra concentrated dose of Griot's car wash which will remove wax. You can use Dawn dish soap as well. Once I washed and hosed off the areas I went over it with claybar to make certain I removed any contamination that may affect the performance of the vinyl.
Heat:
I used my wife's hair dryer to soften and shape the vinyl anywhere I need to conform it to curves. The vinyl will have a tendency to stretch back to it's original state after a while. Installers recommended that I heat the vinyl to 210 degrees so that it would stay conformed to its installed shape. A thermal reader helps here.
Naca Duct: The write up doesn't get into installing Vinyl in the naca duct because it was done on a Gen I. I think having the vinyl go through the naca duct, and license plate area, gives the job that finished look. After going through about 10 feet of vinyl, I decided to use 3 pieces of vinyl in the naca duct. I could not for the life of me get a solid piece to conform to that area. Unless you looked at it very closely, and ran your finger inside the naca you cannot tell it was done in three pieces. But it worked and came out looking great. If anyone is interested, I can post closeup pics of what I'm talking about.
Squeegie: DO NOT USE A HARD PLASTIC squeegee on Vinyl. Trust me...it will scratch. Use a felt-covered squeegie. I found that the California Jelly Blade worked perfectly. It does not scratch and does a magnificent job of removing water/air bubbles out from under the vinyl.
Duster: The California Duster was a great help. A quick pass of the duster over the car and the dust is gone. This was very helpful as I took breaks between installations on the car. Dust would build up over a few days and if left uncleaned it will show up under your vinyl.
Other than using soapy water, a squeeze and some elbow grease (sharp razors) this was not a very difficult process. If you have time, I highly recommend it. It can be done in a day. Plan on at least 6 hours if you've never done this before.
My final step is to complete the 'Baz Mobile 2' by installing a striped Mopar wing...just like Baz. :D
- Tony
2002snake
FINALLY HOME AND PROUD TO BE AN AMERICAN !!!
I want to put silver stripes on my Graphite. My stripe guy said he would have to put clear over it because the silver stripe material fades and oxodizes from the sun. The clear makes the silver stripes thick.. Does anyone know if this is true???
IEATVETS
Cottage Grove, Wis.
Your stripe guy is an idiot!:omg:
I know others will chime in on this one as well but the material does not oxidize or fade. I had silver vinyl on my RT for over 2 years and never had a bit of trouble with it. Even when I took the vinyl off to have stripes painted on, there was no fading of my paint either.
You DO NOT have to clear over the vinyl. Sounds like somebody wants to charge you for something you absolutely don't need.
V
ViperTony
I would love to do the same thing with mine. What color are your wheels?
I have stock wheels. I think black wheels would be a nice addition to stripes.
I agree with IEATVETES. Although I used Avery, there are other brands out there like Oracal and 3M. Along with Avery, their vinyl is made for outdoor use for up to 9 years (premium, unprinted), 5-7 years (standard). I don't believe clear coat is needed. If I'm not mistaken, I think early Vipers had vinyl stripes and were then cleared over. Make sure your installer is using fresh vinyl. Some of these manufacturers limit the shelf-life of their vinyl products. The A9 had a one year shelf-life. I've seen some very nice metallic silver stripe vinyl on vipers and it looks amazing to me.
Looks fantastic!
how long did it take?
Thanks! I did it over the course of a week. An hour here and there whenever I had time to sneak out to the garage. In all it took me a good 8hrs but I made a lot of mistakes because I never worked with vinyl before. So I took my time. The hood, hard top, trunk top were cake. The difficult parts were the naca duct and bumpers, at first. Once I figured out how to heat the vinyl, stretch and form it to the curves it got easier. I'm certain I could do it a lot faster.
My final step is to complete the 'Baz Mobile 2' by installing a striped Mopar wing...just like Baz.- Tony
Looks GREAT! I may have told you about doing my Blue Stealth TT in white vinyl from a sign shop. You did a BETTER job than I did back in 1993. Glad we could help with advice, if not product.
We CAN provide the MoPar wing nicely under $600, and some nifty bumble-bee free viper doo dads to go along with your order
2002snake
Thats the best news I've heard yet. Thanks for your post. I think This will be my next MOD. Your care looks great . Was there a time that you wanted to pull your hair out?? LOL I have no problem telling the stripe guy that he is an idiot......
V
Venomiss
Guest
Way to go! Looks very good and hopefully you consumed a beverage of some sort after it was accomplished.:2tu: Nice tips for a Gen2 to share with everyone.
V
ViperTony
Thanks Venomiss. Actually, I was drinking lots of beverages during the process...which may have contributed to how long it took. :D
Thanks Jon. I noticed how timely and conveniently the pricing changed for the Mopar wing on your site. :D With a limited budget right now, I think my next priority is new tires. My tires are over 7 years old and I was reminded several times today while performing some spirited driving that I need new tires.
................Thanks Jon. I noticed how timely and conveniently the pricing changed for the Mopar wing on your site. ... With a limited budget right now, I think my next priority is new tires. My tires are over 7 years old and I was reminded several times today while performing some spirited driving that I need new tires...
You made me curious, so I lowered the price a bit today, just to display our pricing history. We have not changed the price on that item for many months....
PS, did you hear, we have great prices on TIRES too? "Best Price Promise" ... Wing+Tires save even more, Tax Refund Sale!
cudavip
Yellow GTS black stripes buzzzzzzzzzz on, yellow RT/10 black stripes, swat it-just does'nt flow.
To each his own.
V
ViperTony
They're not the best pics but they're 4" apart. Actually, they're 4 1/4" to be exact. If I had to do it again, I think I'd try 10" wide stripes instead of 8".
