Jesel J2K Mohawk Shaft Rockers tested to extremes...
Sean Roe
Jacksonville, FL
Hi Everyone,
We installed the first set of Jesel brand rocker arms available for a Viper this past September. We've run over 40 dyno pulls, numerous track full gear pulls and exceeded 880 rear wheel HP and 1,050 rear wheel torque with them.
They are by far, the strongest and best rocker arms available for the Viper today. We knew going in that they were good, but the are truly the best there is.
We now make the Jesel rocker arms available on our website.
Fits 1992-2002 Vipers
Standard ratio is 1.7:1 Available in custom ratios. The ultimate balance of mass, stiffness and strength.
Features include; Torrington shaft needle bearings, needle nose roller bearing, 7068 alloy body, shotpeened surface finish, tool steel lash adjusters and fully machined computer designed profile. ARP mounting hardware is included as well as an adjustable pushrod for determining the correct length (designed to fit stock length pushrods and fits under the valve cover baffles without modification). Lightweight, yet ultra rigid design improves valve control and is easier on the camshaft /lifters. Please call for custom ratios and pushrods.
Part #0509-509, priced at $1475 (comparable to T&D brand with needle roller bearing tip option).
You'll find them on our www.RoeRacing.com website under Viper Parts, Horsepower Upgrades.
Regards,
Sean
Jandrix302
