I went to the dyno in the rain today and had my set up dynoed for the first time.
***The conditions were the following.
***Wet out side/ tires wet /some slippage on the dyno
***About 55 degrees outside
***Major belt slippage from pulley
***No blower or fan in front of the car to move air.
***6-8 PSI loss from belt slippage
I found out that my Riechard Racing Pulley was slipping and eating my belts up. I had chunks of belt coming off..I'm not saying his pullies are bad...it just didn't work for me. On a typical pulley of my size, I would be at impeller speeds at about 55,000 rpms...which should equate to around 14-16 psi. With the slippage, I only saw 8.2 PSI
I still need to adjust my fuel map, but overall I was running 11.4-11.8 little lean, but not too bad. It dipped down to mid 10's at times, but that can all be adjusted at a later time when I get more time to mess with it. I had about 6-7 degrees of timing being taken out just to be safe on the first dyno runs.
I got 740 RWHP/ 728 RWTQ with my set up and I have plenty more to go after when the belt slippage issue is taken care of. (should gain 6-8 psi more) It's not what I wanted for right now, but with the conditions I had it's not too bad for a start.
I want to thank DLM for advice and the time Doug has spent with me just chatting and helping out unselfishly. Doug is truely a person who really cares about helping others when he can and does it unselfishly without expecting favors in return.
I am pretty excited about getting the minor stuff fixed and I will keep you guys posted on my further results.
