Just got back from the dyno
Franko
San Diego, CA
My mods are a K-n-N Intake and Borla Cat back exhaust.
1st run: 440.3 rwhp 457.4 rwtq
2nd run: 445.5 rwhp 455.6 rwtq.
After 3500 rpm's it REALLY went rich. I'm sure i'm out some power but i suppose it's safe.
I'll try and have somebody scan it so you guys can check it out.
Thanks!
Frank
SnakeEye
Austin, TX
Good baseline dyno runs. The Paxton you list as coming in your sig will give the gigantic kick you need. Don't forget to share those post install dyno runs too. :2tu:
I agree about the torque readings. The PCM most likely goes into open loop around 3500 rpm and dumps fuel to fight knock.
Ooomph
Rio Rancho, NM
There's no knock sensors on the 03's. I would've figured the dyno numbers to be higher, especially with the Borla's. With just the K&N system my '03 put down 449.4hp/489.0tq to the wheels. I'd take a close look at the fuel trim as our engines find peak-tq at ~ 4k rpms, which also happens to be directly after your engine see's a rich condition. :confused:
